Got our new X754
   / Got our new X754 #1
holtzacres
Manchester, IA
New Holland Boomer 3045
We got our new x754, probably wont be able to try it out as there is snow on the ground now. guess we will just sit on it and look at it for a few months until spring.
   / Got our new X754 #2
Very nice - Congrats.
I was very tempted to go with the X754 to get the 4WS, but I have some areas where my old 2WD spins out, so wanted the 4WD as well. Compromise was the x739 - gas - not diesel. Bit of snow here in last few days, so mine will be sitting until spring as well.
   / Got our new X754 #4
You guys need the 47 inch quick tach
Blower and use those machines.
I have an X724 with blower and blade
And have great results with both
Also 62 inch mower deck
   / Got our new X754 #5
   / Got our new X754 #6
If you have included me in your "you guys need......." suggestion - I have a 60" Snow Blower on the 3320 CAB - where I can sit in heated comfort with an adult beverage, so the X7 will be sitting in the heated shed until spring.:thumbsup:
   / Got our new X754 #7
I'm curious. What holds the front wheel on? It doesn't appear to have the normal lug bolts/nuts.
   / Got our new X754 #8
My apologies Cindy or CinderSchnauzer yes you are included and NO disrespect intended. Yes with that larger equipment I get your point and you must have a lot bigger area to clear.
I was just indicating the 47 inch unit does a very good job for its size
   / Got our new X754 #9
jgayman: On my X724 a bolt and washer hold the ball bearing unit in place and are covered by a rubber cap. I think tractors with 4 wheel drive have 5 bolt front wheels
   / Got our new X754 #10
Thanks. That was about the only configuration that made sense but I couldn't find any photos that showed a close-up of the wheel.
Land Honor Skid Steer Bale Spears (A50515)
Land Honor Skid...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
Danuser Digger F-8 (A52748)
Danuser Digger F-8...
2013 John Deere 6105D (A50120)
2013 John Deere...
2019 KOMATSU PC290LC-11 EXCAVATOR (A51242)
2019 KOMATSU...
Wolverine Mini Skid Steer Auger Drive & Bit (A50514)
Wolverine Mini...
