Got myself a tractor :-)
/ Got myself a tractor :-) #4
4630 Ford? If so that is a great size machine that can do a lot of work.
More details
FEL? MFWD?
/ Got myself a tractor :-) #5
Welcome no shortage of folks who agree with you (always wanted/needed a tractor). Myself included. I needed one but wanted one I didn;t have to work on all the time.
Look through the old posts and I bet you learn something along the way.
More details
FEL? MFWD?
Yep 4630 Ford, 1993 year, 4wd with bonfield front loader . Sorry don't know what FEL or MFWD means...... New to all this.
I do have a hydraulic leak from the deluxe remote, so that is the first repair.... Probably of many, so hoping this forum is a great place to help.
/ Got myself a tractor :-) #7
Awesome, FEL is Front End Loader, Check,
MFWD: Mechanical Front Wheel Drive. Check
4630 MFWD with loader, That was my dream tractor.
My 3000 Ford was a great tractor and I think you will really like the 4630, It is a really robustly built utility class machine.
I am not familiar with that loader brand
How about some pictures of the new Ford? We members Love Pics @ TBN
Thank you. I'll get some pictures sorted at the weekend 😁
/ Got myself a tractor :-) #9
Welcome toTBN...enjoy.
You got tractor in your blood now and there ain't no cure. ;)
/ Got myself a tractor :-) #11
While we wait, here is a picture of a used cabbed 4630.
So much to Like with this Ford model.
Heavy duty front axle including planetary hubs. Made to work and with the 3 cylinder large bore diesel it keeps the wheelbase a bit shorter than the 4 cylinder Fords, which also helps when working in tight quarters.
These older Fords will pull hard with excellent torque, even down at 800 RPM.
Another desirable feature- No small diameter rough riding front tires.
12.4" x 24" R1's a full 45 inches in diameter... bigger than some CUT REAR tires.
I am excited for the OP, these are Very capable machines. Congrats !
tractordata info is Impressive: Lots of PTO power.
PTO HP tested @ 56.8 HP
Cat 2 or 1 and lift of over 3K lb.
FELs are from 2300-2700lb to full height at pins.
Caterpillar 12H/140H/160H Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
PALLET OF BELT, PUMP, ESC (A63291)
PALLET OF BELT...
Auger Drill Bit Skid Steer Attachment (A61572)
Auger Drill Bit...
Takeuchi TB225 (A62177)
Takeuchi TB225...
