Got laser?
   / Got laser? #1
4440
Kentucky
JD 4440, JD 5303, JD 3038e, JD 250 skidsteer, Kubota L35, ASV 70, Bobcat 743
We in the process aquiring a used Trumpf 3030 4000 watt laser. Myself and the prospective operator have been undergoing training from the sellers. Next week we will meet up with a serviceman and machinery movers to package and move the machine to our shop. Hopefully the machine will be in operation with the next week and a half. Currently we run a Bystronic Bystar 3015 which is overdue a good overhaul and anytime. With the addition of the second laser we will be offering custom cut metal packages for the build it yourselfers. Some of the other services currently are laser, brake, machining, and powder coat.
   / Got laser?
Here is a picture of a Trumatic 3030 just like the one we are getting.
   / Got laser? #3
Is this one with a double table, so you can load/unload one, while the other is under the torch ?
At a former employer of mine they used a similar one, just a 2.2 Kw one.
with 4Kw you should be able to cut up to about 25mm if needed, though plasma is cheaper at 15mm and more..
   / Got laser? #4
Very nice. Looks like it will cut up to 20mm (3/4"+1mm).
http://www.ad-am.co.il/Laser+Press/TRUMPF-TC600-ihs-gmbh.pdf
How do you price cutting services, e.g. by the square inch length x thickness? Or just send a dxf file for a quote?
Right now I am helping my buddy design a backhoe thumb for his JD 310SE. We are planning on using 3/4" hot rolled. Ready-made thumbs that size start at over $800. It would be nice if you can offer a kit with the cut parts - we were just talking about the need for that kind of service at a good price.
Brad
   / Got laser?
I would prefer a dwg file of what you are wanting. PM me through the boards here for my contact info.
   / Got laser?
Our prices are all based upon design time, setup / laser run time, and material used. Our Bystronic and Trumpf both have 2 pallets or tables so that you can continuiously run. As far as the benefit over laser v/s laser there is no comparison. When we first started in the 90's we had a Weidman CNC plasma / CNC punch press with 18 index stations. Since we got the Bystronic laser is '95 we have never used the CNC plasma on the Weidman again only the CNC press.
   / Got laser? #7
Lasers are amazing. I use them in some typesetting equipment. They won't cut me like yours, but they will blind you permanently. :shocked:
The advances over the last decade are impressive, to say the least. :thumbsup:
   / Got laser? #8
I remember a modified sign at work:
DANG!
LASER RADIATION
Do not look directly into beam with remaining eye.
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2009 DRAGON  130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
2012 Ford F250 XLT, Super Cab Long Bed (A52384)
2012 Ford F250...
