Got it!
   / Got it! #1
Fullthrottle
Bronze Member
SC
NH TC45
Received my TC45 yesterday. 1.6 hrs so far and I think I made a good choice. Got a 6ft Woods finishing mower and a 6ft Bushog 286 brush cutter. Will have a FEL installed in a couple of months.
   / Got it!
Went out this morning to pull up some old fence post with the boom pole and chain, but had to stop and work on old blue. The parking brake would not stay engaged. Looked like the teeth were too close together on the bottom side of the lever. I pulled out my trusty grinder and disposed of one tooth and now I'm back in business. Kinda concerns me though. You would expect the simple things to function properly on a new tractor.
   / Got it! #3
I've heard of the parking brake problem sporadically in other posts. I've only had a "problem" with mine once, but it turned out to be mud in the mechanism for me. Otherwise, mine has worked perfectly. I agree with you that this "simple" thing should work well. After all, safety is the issue here.
JimI
   / Got it! #4
Re: Bush Hog 286
How does your TC45 handle the 286BH Cutter. Mine is very hard to raise off the ground when adjusted correctly. It appears that the pins need to be lowered on the frame so the tractor will lift it higher. My tail wheel barely clears the ground in full lift, and bumps the ground while traveling.
2020 COLOMBO TM LOT NUMBER 218 (A53084)
2020 COLOMBO TM...
Mini Skid Steer Sweeper Attachment (A51573)
Mini Skid Steer...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
Pallet of (15) 10 Lug Misc Wheels (A51573)
Pallet of (15) 10...
Chevrolet C8500 Flat Bed with a Moffet Kit (A53472)
Chevrolet C8500...
