Gooseneck repar/rebuild
   / Gooseneck repar/rebuild #1
Louisiana_John
Louisiana
65-56 HesstonMFD,FEL,Kubota 7040 cab/4wd, Kubota mx5000 4wd, 99 Cat D4C LGP, Deere 120C. Roller, Mini X, Deere 770 Grader,
I started tearing down my trailer the other night. I have owned the trailer for 9 years. It was an ex east TX county trailer. I bought it from the MFG for $ 1800. Not bad for a Duel tandem. I had to cut about 15 pieces of c channel off. Whenever a board would rot the county would change with c channel. I am also adding a drop to the neck and making a little longer with an adj coupler. I have a 9' bed coming for my 3/4 ton. The trailer has 1 newer axle under and one older one. I bought new springs and hangers, 1 new axle. I am going to take and get sandblasted and painted when done.
I am going to add new lights and a RK under frame box for chains and binders, new jack, wiring and tires.
It seems like a lot of work till you see the price for a new well-built Gooseneck. I will take my camera out to the shop tonight and start posting the progress.
John
   / Gooseneck repar/rebuild #2
Re: Gooseneck repar/rebuild
Good luck w/ the project. what county did you get that trailer from? I live in Bowie and seems like there was a county auction recently but I couldn't make an appearance.
It was a Panola county trailer. I have had and used for 9 years. I have bought 1 tire some grease and seals in that 9 years it has been a good trailer. Here is the pic were I am at know. I hope to have it ready first of next week to take and get painted.
John
[image]
[/image]
   / Gooseneck repar/rebuild #4
hi,
could you get a measurement or 3 for me? i'm converting a pintle hitched backhoe trailer to a gooseneck.
what kind of metal is the gooseneck portion made out of? 8 inch channel? 10 inche channel?
thanks!
I did that for my uncle. I did what my trailer MFG did. 8"channel with 7" layed in side to make a box. They still build there trailers that way. They do alot for heavy oil field work. My was used to the max for 14 years by a county behind a 2 ton truck. No cracks or bends in the neck. I am adding 6" to my neck. So I am putting the first 30" at a 25 deg angle to the hitch. From the frame to center of the ball is 84". I will take more pics later. I got the new axle under and all new springs and hangers this weekend. I also installed new jack. I got my neck laid out and one side cut and tacked.
The way I start on the neck is make a jack stank for the hitch and get it square to the trailer. I mean get were it will end up when finished. Then use strings and a speed square to build to the hitch.
I bought me a new tool that is great an Arc Gouge. I used it to cut the weld out of the old hangers. It did it job and left the trailer beam looking new. You could just sit there and just cut out the old weld like butter.
John
   / Gooseneck repar/rebuild #6
Is an Arc Gouge the same thing as an Air Arc?
Basically a welding torch that has a air vent to blow the weld puddle away when it gets molten, and uses carbon rods?
Been known to have to cut a weld out a time or two...
I have a triple axle out back that needs to be straightened, and the gooseneck removed, since I don't have anyway of pulling it. (Pintle hitch coming)
David from jax
Yes, it is the same. I am about done I hope tonight. I need to take and get blasted and painted this week. When I pull out of my shop I will take some pics.
John
   / Gooseneck repar/rebuild #8
interesting! i've got a pintle hitch trailer i'm converting ot gooseneck becuz i have no good way to pull a pintle!!!!
   / Gooseneck repar/rebuild #9
drmiller,
A pintle hitch is easily done, if you have a Reese hitch on your tow vehicle. Just pick up one at your local autoparts store, slip it in the receiver and hook to the trailer.
The fifthwheel from a pintle hitch requires a little more $$$, because you have to purchase a hitch worth a couple of hundred dollars.
If my trailer didn't have problems with it, I would probably just purchase one and be done, but the trailer needs work, so the easiest way (and cheapest) is to go to a pintle hitch.
David from jax
   / Gooseneck repar/rebuild #10
oh, i've got a superduty, but it is pretty light for the trailer. trailer is 5k, skid steer is 8k. would be a lot better pull if gooseneck.
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2007 International 4300 Box Truck, VIN # 1HTMMAAL07H360176 (A51572)
2007 International...
2005 MACK GRANITE (A52472)
2005 MACK GRANITE...
Electric Forklift Pallet (A50322)
Electric Forklift...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
