mjw
I have several projects that require heat to remove stuck/broken bolts (gotta love salt).
I sold my portable oxy-acetylene set years ago as I didn’t use it but once.
All I have left are little hand held propane torches that will heat but take forever and throw too much heat into the surrounding area.
I am looking for hot and pin point heating.
The benzomatic ts-8000 map/pro gas keeps popping up, cost $50-$60.
A remote torch head might be nicer for at least one project, space is limited, not even sure I can get a torch head in the limited space.
Any recommendations for a small budget torch to just heat up some rusty bolts?
Or maybe even a larger oxy/propane setup, they look interesting and I have enough uses.
Obligatory tractor content- I need to get these car projects out of the way so I can tackle the bad PTO bearings on a JD 335
If I don’t get a new torch I am going to break down and take the minivan to a well trusted mechanic in town, I guess there is a first time for everything.
I cannot chance breaking off another bolt in a engine head/intake/block, at least not on my daily driver.
Just realized I posted this in projects instead of welding. Oops.
