Price Check good price on 8n
   / good price on 8n #1
genebogart
ferguson to 30
Been looking for a nice used tractor for some land I own upstate Pa. need it for driveway maintenance(about 1/2 mile) keeping the weeds down along the road and maybe pushing some snow. Found an 8n original paint, no smoke on cold start seems tight and sheetmetal is straight. No apparent oil leaks, still 6 volt i can get it with a sickle bar for 3 pt hitch for $2500. Does this seem about right. Its a little bigger than I wanted but better bigger than too small. Also want to plant food plots and a big garden any thoughts, the small compacts are expensive and dont seem built as well.
   / good price on 8n #2
tractor alone around here goes for about 2500
   / good price on 8n #3
That would probabally be about the upper-end of what they bring here.
Average tractor in average condition usually brings 1500-2000. They are all different though. Rebuilt/restored ones only fetch 3000-3500 in my area.
And if it happens to have the sherman over-under drive unit, that adds value as well.
   / good price on 8n #4
For every hour you use it you will be repairing it. points plugs roter coil, carb leak, over flow, fluding, oil leaking on brakes- repeat over and over-.F.O.R.D.-FIX OR REPAIR DAILY. Sold mine after 5 years for $1800.00 It taught me a lot and I sometimes enjoyed working on it.
   / good price on 8n #5
8ns are good tractors an yes you do have to work on them when things go wrong.but you also must remember they started making them in the 30s.around here they bring anywhere from $1500 to $3500.the topend being pretty much fully restored.
   / good price on 8n #6
The original paint and 6 volt are good signs. If the rubber is good then that is a good price. If tires are questionable, then price is a little steep in this sputtering economy which has seen old 2wd tractors off in price a minimum of 25% from what they went for about 3 years ago. There is no sign that those old tractors are going to gain value anytime soon. The 8n is probably the most dependable older tractor made and the least likely to require lots of work. Heck, I havent hardly touched my 1951 in more than 20 years other than oil and filter changes. To be fair, I did put a new 6-volt battery in it this spring but the old one had been in there 10 years. I dont typically get that kind of life from 12 volt batteries. In those 20 years, my (5) other tractors, all newer and most accumulating less hours, have needed as much or more work than that old 8n. I actually wore out a Ford 2000 diesel in that time, as the old gas-powered 8n kept pulling strong. One things for sure, no tractor is going to be easier to find parts for when and if it does break down. If it is a 1951 or 52, it will have a proofmeter, and these are worth a good bit more than the others, especially the older 9n's and 2n's. In my opinion the 1951 and 52 8n's were the high-water mark for the Ford tractor co, and there is no other that I would consider owning unless it was given to me. That 2000 I owned, and a 3000, Jubilee, and 600 that I ran, all soured me a bit on Ford's later models, as I have had a lot better luck with OHV engine tractors from other manufacturers. Ford just couldnt get it right after the Patriarch passed I guess. When it comes to flatheads however, you cant beat them old Ford n's.
Dion 1224 XC Silage Chopper (A50515)
Dion 1224 XC...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
24' Free Standing Panel with Swing Gate (A50515)
24' Free Standing...
2852 (A51691)
2852 (A51691)
