Good plans for solar pond aeration?
   / Good plans for solar pond aeration? #1
dwightv872
Kubota
Looking for ideas (and plans) for a reliable, inexpensive solar aerator for a small farm pond.
   / Good plans for solar pond aeration? #2
I've seen reliable solar aerators. Inexpensive and simple - NO. But they were the only ones I've seen. They were the industrial/commercial type. At one time - I considered this for my ten acre lake.
Cost and maintenance were the reasons I didn't purchase one or a system.
   / Good plans for solar pond aeration? #3
I'm with @oosik; I know of cheap ones, and I know of reliable ones, but there isn't any overlap that I know of.
What is your goal with the aeration?
Is it a big pond? A shallow pond? Do you have excess water? Fish? Algae blooms?
For cheap, I would think of a vertical windmill (55 gal. Drum cut in half) on a shaft turning an impeller wheel at the surface, but check your maximum wind speeds, and think about a clutch or a brake.
All the best,
Peter
   / Good plans for solar pond aeration? #4
Do you want a bubble system or do you want a fountain system?
I would think that a bubble system would be far easier and cheaper to install and maintain than a fountain system. But then you might just want the fountain cause they are pretty to look at. For a bubble system, making your own would be fairly easy. Since its outdoors, you don't need UL listed solar panels, and these used, can be as cheap as $50 for a 100 or so watt/ 12v panel. At least in my immediate area, these are available locally. The air pumps look to be in 30 to 50 dollar range. I would get a 24 volt air pump and set up two, 100 watt, 12v solar panels in series. And you can make your own bubbler tubes. I would check what the the amount of noise the pump makes before purchase. It should be quiet. A system like this doesn't need any control switching, its always on. And I would not care how the panels are orientated, as efficiency isn't that important.
Fountain systems can be a pain to maintain, as you will have to filter water to the water pump somehow, and nature WILL find a way to mess up that filter. A bubble system doesn't have this issue. :)
   / Good plans for solar pond aeration? #5
Back when I was a boy scout, I stumbled upon a homemade pontoon boat about 4' x 8' floating in the center of a small pond. The boat had a 6' tall windmill with a shaft driving a propeller just under the surface. Both ends of the boat were tied off with a cable running from shore to shore to keep it centered.
That was the coolest collection of scrap materials I had ever seen.
Mini Excavator (A52377)
Mini Excavator...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2005 Frieghtliner 18' Box Truck (A52377)
2005 Frieghtliner...
1982 LeeBoy Motor Grader (A53473)
1982 LeeBoy Motor...
2016 Chevrolet Colorado Pickup Truck (A51692)
2016 Chevrolet...
2013 Land Rover Range Rover Sport 4X4 SUV (A51694)
2013 Land Rover...
