Good leaf blower?
   / Good leaf blower? #1
Phils
Platinum Member
Cherokee, CA
PT-422
The search function appears to be not working, similar to this whole site earlier, so if there's a relevent thread I couldn't find it.
I am hoping members of the TBN collective mind have some good recommendations for a leaf blower. I refuse to use the one I have ever again. It's an Eager Beaver that I bought maybe 15 years ago, but I haven't used it more than once a year before now. Runs great, but the exhaust blows back at the operator making clothes stink, making it very hot on those clothes and skin and making me inhale the exhaust the whole time. If I hold it to the side to avoid the exhaust it wants to keep sucking my clothes against the guard. It's obnoxious to use in other ways, but those complaints are the major ones.
I have maybe an acre total of gravel around the house and outbuildings I'd like to clear of leaves a couple of times a month, but I've always hated that blower so much I just avoid job altogether and let the leaves pile up.
I'm guessing a backpack-type would eliminate most of my complaints. I don't need professional grade but if that's the only choice I'll find a bullet to bite.
Any suggestions?
Phil
   / Good leaf blower? #2
Stihl, Echo, Redmax are all good brands tha are heavily used by professionals.
I've never used a backpack blowr but I use my handheld Stihl BG55 very often and I have no complaints.
   / Good leaf blower?
Thanks, Rick. I'm not committed to the backpack style, just want something that directs the exhaust away from the operator without directing it at a pile of dry leaves. I'll put that model on my list to check out. I have a Stihl chainsaw and already appreciate the brand.
Phil
   / Good leaf blower?
Been doing some searching online and realize maybe an electric blower would work for me so if anyone has recommendations in that style please include them. I don't EVER use it as a vacuum and most (if not all) of the bad reviews I found referred to the vacuum function.
Phil
   / Good leaf blower? #5
Phil,
Can't help you with an electric blower, but I have had a Stihl backpack blower for 5 years now and am very happy with it.
Will
   / Good leaf blower? #6
I'd stay away from electric unless you have a very small yard. I'm willing to bet if you buy an electric you'll later be wishing you bought a gas model.
The Stihl BG55 and BG65 are darn good, especially for the money (easily less than $200). I have the BG55 and wish I would've spent the few extra dollars on the BG65. They both have the same exact power but the BG65 has a rubberized grip, a second higher speed nozzle, and thumb throttle.
   / Good leaf blower? #7
I have an electric but I'm not covering near the amount of area you are. I have a Black and Decker Leaf Hog. 230MPH and that thing can definitely move leaves, rocks, and lots of other stuff in the yard. I run it on a 50ft. extension cord in front of my house(sidewalk and driveway and flower beds). So I didn't really need a gas one. My dad tried to talk me out of the electric, but for my needs it works very well.
   / Good leaf blower? #8
The BG 55 and 65 are the exact same blower in all regards, except teh 65 has a slightly higher airspeed while the 55 has more volume......
easily solved by buying a flat tube for the 55 which gives you the same velocity as the 85. If you look at the specs for the BG blowers when the air velocity goes up, the cfm (cubic feet per mintue... volume) of air goes down, the BG 85 uses a flatter tube thus giving it more velocity and less cfm while the BG 55 uses a round tube giving it more cfm and less velocity. What does this mean to us?..... With more volume and less velocity you can blow leaves and grass clippings out of rock garens and flower beds without blowing the rocks or mulch out. With more velocity and less volume you can blow stuff faster/farther (like cleaning off the entire yard). What I do with my BG55 is I take the flat tube off and carry it in my hand while blowing out the flower beds or rock garndens of the yards I maintain and then snap and twist the flat tube on to clean offf driveways, sidewlks, streets etc.
For what it's worth I think the Stihl gutter kit is worthless, it works beter to get on the roof and blow them out. The gutter kit flies apart (it needs some pto lockpins drilled and placed in them to hold together better) plus it throws the stuff out and on top of your head/in your face. The stuff in gutters is usually about half rotten and wet.
I looked into the BG 55, 65 and 85 and went with the 55 because it is bascially the exact blower as the other two and it was the best bang for the buck. Don't get me worng I'd rahter have the backpack blower but I didn't feel like shelling out that much for it the BG 55 does what I need to do and will do everything a homeowner will ever demand of one.
Go with a gas blower over an electric, you will find you use it for a lot more than you think you will.
Besides blowing leaves they also work great for:
cleaning behind the fridge
cleaning the shop (sawdust on the floor, equipment, etc)
open all the doors in your truck, turn blower on and blow it out
cleaning a bushhog deck off after mowing, blowing the S*** out of the tractor knooks and crannies after mowing
cleaning a combine after harvest season
take it up on your roof and blow out your gutters
Cats hate them
I use mine often for cleaning the dog pens out when the S*** is dry
cleaning out haylofts
cleaning off the deck of your trailer, bed of your truck, etc
   / Good leaf blower? #9
The BG 55, 65, and 85 have the same engine.
They also work great for "fanning the flame" of a fire that just don't want to take off right!
   / Good leaf blower?
Thanks, all. OK, gonna go with gas. I'd be dealing with two 100' extension cords otherwise. My reasoning for getting an electric was that with one maybe SHE would do the blowing. I'll limit my vent to simply state that it puts me in a less-than-good mood to be using that **** blower I have now (choking on exhaust, arm hurting from trying to hold it away from my body, etc.) when SHE comes out and starts pointing out the places I've 'missed'. Grrrrrrrrrr........
Since TBN was down yesterday I found some lawn and garden forums and was able to search and come up with quite a few posts about "which blower is best for me?".
Stihl units work well usually but quite a few have starting problems (only the blowers, and only some). One thing that was mentioned frequently was to buy from a dealer vs a big box store.
I saw no bad posts about Echo. Comparing units, the PB261L seemed like a good choice (it's model number is 260 if it's not California smog certified). I went to a local Echo dealer but they didn't have one of that model in stock, instead recommending a 513 (or was it 613?) that was only $30 more but 44cc instead of 25cc, with a corresponding increase of CFM, although MPH was about the same.
However, that one is 9 pounds heavier than the 261 so the dealer is ordering one in (no obligation to me) and I can compare them side-by-side on my back and running. I told them no hurry so it'll be about a week before I can compare. I expect I'll like the 261 just fine and at almost half the weight of the other one will likely be the one I buy.
They quoted me the same prices as HomeDepot ($270) so I guess Echo enforces price controls. I had expected and was willing to pay a little more to have dealer service.
I'll post back with the final decision when I make it but will still consider other posts with suggestions.
Phil
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
2019 Allmand Bros Maxi-Lite II S/A Towable Light (A52377)
2019 Allmand Bros...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
Toro Mower (A50324)
Toro Mower (A50324)
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
