Good homeowner welder?
   / Good homeowner welder? #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
So I haven't welded since about 1992, but I think I can pick it back up pretty easily with some practice. Since getting a new tractor and trailer, I am seeing more and more instances where having a welder would be handy. I do have a good local welding shop that doesn't charge too much, but it can be a pain to bring them plans, materials, etc -- it would be easier to clamp stuff up in my garage and just get the job done in minutes. Even being able to tack stuff myself would really be a help.
I still have all my old tools -- clamps, gloves, mask, grinder, etc. The only piece missing is the welder.
Does anyone have a suggestion for a good basic welder for homeowner use? I looked at a small 115V Hobart wire feed MIG which seems like a decent unit, but it's limited (by power and wire size) to about 3/16" material. That would cover much of my use, but not the big stuff (though I could use it to tack the big stuff and then bring to the welding shop). I'd like to stay under $500. I don't have convenient 220V access in my current garage, so a 115V welder would be better. We are in the process of building a new place where I will have a nice workshop, and can wire that for 220V and upgrade to a bigger welder then if it's needed.
If I wanted to use a bigger welder at my current house, I'd have to run a line into the kitchen or laundry room and commandeer the stove or dryer hookup. Not sure my wife would dig that, but if anyone else has done something like that, let me know.
If the 115V welder isn't worth the trouble, that would also be good to know.
I'd appreciate any thoughts/advice you guys may have. Thanks.
   / Good homeowner welder? #2
I personally would not have a 115v welder as my ONLY welder.
I use a hobart 235AXL AC stick welder. It's beefy, and was cheap to purchase. It's priced just a hair less than a lincoln 225a tombstone and has a few benefits over the tombstone IMHO.. .. 1, a lil more amps on the top end.. ( no big deal ), and I like the infinite amperage adjustment lever, vs the pre-set switch positions.
I DO have a 115c stick welder to use 1/16 and 5/64 rod for detail or sheet metal work.. but any real welding gets done on the big stick.
for farm welding and fabrication.. it's done everything I've needed including large heavy weld repairs involving 3/4" material and large / heavy implements like a batwing mwer..e tc..
in practice, the lincoln tombstone ( still on sale at lowes and home depot for 285-299$ ) is just as good.
that's the opinion of a someone who is not a 'real' welder, and does not own 'real' welding equipment, as one of the pro welders here would (constantly) point out.
soundguy
soundguy
   / Good homeowner welder? #3
Well I have a lincoln tombstone I got used, and it works good. It burns 6011 and 7018ac quite well. I have a longevity stickweld 250 dc stick welder in the mail to me now, it will be here tomorrow. They are about $450 (I got mine as a thoughtful donation from longevity). They have infinatly adjustable amperage, and adjustable arc force and hot start. I will try it out tomorrow with some 7018. If it works well, I would defenatly recomend it over a tombstone. The stepped amperage gets to be a real pain.
Well, I first learned on a Lincoln arc welder, and can't say it ever let me down. So maybe I should just go for that type of unit (can't beat the price/capability) and work out 220V wiring.
   / Good homeowner welder? #5
If you are going to weld and cut, then why not use Oxy/Acet?
From not a real welder.
RC
   / Good homeowner welder? #6
Go to your breaker panel and take a look. I should be easy to see how the drier is wired in. Most panels have space for more breakers and it is easy to wire in anther circuit.
If you are not comfortable doing that. Ask a qualified friend or hire someone, even that should not cost much.
I see good welders on Craig's list all the time, some almost new looking for under $200. There are some dreamers there asking new prices for old junk.
Can't go wrong with a Tombstone or Hobart. And if you ever upgrade it's easy to get your $ back.
Again from a non pro welder. I just goober things together.:laughing::laughing::thumbsup::thumbsup:
   / Good homeowner welder? #7
Here's one more vote for a 220v AC (or AC/DC) welder. Hard to beat their simplicity and reliability. My advice would be to stay away from a 110v welder if you are only going to have one machine. I have one (Lincoln SP125+), and it is great for sheet metal, but that's about it. Anything much thicker and it leads to a lot of frustration. You also have to deal with a very short duty cycle with one of those small machines.
Corm
   / Good homeowner welder? #8
I just got myself into the welding game. I purchased a Mastercraft AC 230 Amp welder (rebranded Century) for $75 off of Kijiji. Works great. It cost me about $125 for the wire to run 220V to the garage (50ft) and about $55 for a 50A breaker. I also had a length of conduit and the welder receptacle and those items were about $20. So all in all...I wired a 220V plug in the garage for $200.
My welder does not have 'stepped' Amp adjustment but infinite adjustment from 40 - 230 Amps.
That is my setup for $275. That is the price of a new Lincoln AC box.
   / Good homeowner welder? #9
You might want to look at the Everlast and longevity Welders on the forum.I have the Everlast Pa 140 it is duel voltage.I think Everlast or longevity has a 160 amp duel voltage coming out now with a 60 percent duty cycle.
You also can't go wrong with the old buzz box as mentioned. I have used mine for the last 30 years, just recently went high tech with the inverter and have no complaints so far.
My house has 150A service. Of the 220V circuits, the dryer is 30A, stove is 40A, AC compressor is 45A. The breaker box is completely full (last time I added a 110V circuit, I had to use a skinny breaker -- that won't help me for 220V). My brother-in-law is an electrician, so I will see if he has any suggestions. But I am not so sure it's going to be feasible to work in another 220V circuit.
So the dual voltage units have some appeal, since I can grow with them into the next house where I will be sure to have a 220V welding circuit in my workshop. I will check them out.
PALLET OF ELECTRIC DRILLS & SAWS (A45333)
PALLET OF ELECTRIC...
Epson Document Camera (A44391)
Epson Document...
2008 Ford F-450 Ext. Cab Reading Service Truck (A42742)
2008 Ford F-450...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A43003)
2017 KENWORTH T680...
Lely S/A Towable Broadcast Spreader (A42744)
Lely S/A Towable...
2013 International TerraStar 14ft Flatbed Truck (A42742)
2013 International...
