Good Bye to the B3200
   / Good Bye to the B3200 #1
JOHNTHOMAS
Super Member
Somerset, Ky
F2690 4WD RTV X1140 MX5400 HST ZD1211
Marvin from Barlows picked up my B3200 trade in today with part of the implements that go with it, the Landscape Rake. The 12" Auger post hole digger and 6' Landpride RFM are still at my home to be picked up, Hope this B3200 finds a good home:) I've been good to it and only ran it for 34 hours. It always did what I asked it to do which ended up putting his self out of a job.;)
   / Good Bye to the B3200 #2
Do you have other vices hiding behind those garage doors?
   / Good Bye to the B3200 #4
Are those apartment size propane stoves in the pic?
   / Good Bye to the B3200 #5
Why didn't you just drive it around the corner....you live behind the lot don't you? ;) I never thought I'd see you let go of that one. Y...I've got over 2 hrs on my 3030 now and I love it!!! :thumbsup: BUT....I sure could have used your new BX backhoe a couple of days ago...I was in a tight spot...but I had too good boys to help dig, so I was ok. They're heading off to college next year so that's why I bought 2 tractors...I think....to replace them!
Have I seen pics of our new 'un yet?
   / Good Bye to the B3200 #6
JOHNTHOMAS....are you happy with the job your rear discharge mower leaves. I have heard that they leave allot of longer clippings on top if the grass is a little long.
No. Full sized and done gone. Had 5 and gave them to 3 or 4 Churches/charitable organizations and after saying they wanted them and would pick them up, none of them did. I finally set them out front and a young man stopped and said he needed one for a cabin. I sold him all of them for $50. Course, later people have came by wanting to buy one of the stoves I had for sale.:) I just wanted them out of my storage bldg.
kuboman Re: Good Bye to the B3200
Interesting question. When I mow it is always to long. I'm not one for mowing every week or usually evry two weeks. I want my grass long enough to look and see where I've mown without a doubt. It cuts great and lays the cut grass spread out over the cut area better than any side discharge deck I've owned. In fact the spread out part is one of my favorite parts of the rear discharge deck. As I said I don't mow as often as some and when I do with a side discharge there are usually the rows of cut grass. I've never had any mower do as good a job at mowing as the F but that's it's primary function. I had a rear discharge deck that I traded in to Barlows and it did a great mowing job on my B and L tractors. I prefer the rear discharge much more than the side discharge. Only issue with rear discharge on the F is it blows the cutting up on the battery and that's not to much of a complaint.
   / Good Bye to the B3200 #8
must be sad to see a nice tractor go- but then you get a shiny BX to replace it.:thumbsup:
   / Good Bye to the B3200 #9
Interesting question. When I mow it is always to long. I'm not one for mowing every week or usually evry two weeks. I want my grass long enough to look and see where I've mown without a doubt. It cuts great and lays the cut grass spread out over the cut area better than any side discharge deck I've owned. In fact the spread out part is one of my favorite parts of the rear discharge deck. As I said I don't mow as often as some and when I do with a side discharge there are usually the rows of cut grass. I've never had any mower do as good a job at mowing as the F but that's it's primary function. I had a rear discharge deck that I traded in to Barlows and it did a great mowing job on my B and L tractors. I prefer the rear discharge much more than the side discharge. Only issue with rear discharge on the F is it blows the cutting up on the battery and that's not to much of a complaint.[/QUOTE]
Interesting. I will have to give the RD a closer look. The F series is no doubt the best for grass mowing.
   / Good Bye to the B3200 #10
Bet it won't set long on the lot..someone going to be one happy owner.
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2012 International Day Cab Truck Tractor (A50323)
2012 International...
