Good bye Green!
   / Good bye Green! #1
MattLynch
2015 MF 5612
Bought a new 5093E in 2012 and had nothing but problems. Very disappointing.
Tractor had 1200 hours on the clock and spent 2100 hours at the dealer in the 3 years I owned it.
Bought a MF 5612 Deluxe. Pretty much equivalent to a 6125R but didn't cost much more then a 5m. Very impressed so far, not fair to compare it to a 5E but wow, I should have spent a little more and got one of these to start with! Dyna 4 powershift (can shift, de-clutch, foreward-reverse all from joystick), cab suspension, loader suspension, 3 point suspension, armrest controls, brake to clutch, etc. Its bigger then the 5E but way better loader visibility due to the sloping hood, and so quiet inside!
   / Good bye Green!
Also no DPF.
   / Good bye Green! #3
Matt, Big Red looks like a Beast of a machine..
   / Good bye Green!
It's a good size for a do everything farm tractor. Dealer says around 14000lbs as equipped. Needed a lot of ballast handling silage bales with the little Deere, don't even know they are there with this!
   / Good bye Green! #5
What is the FEL lift with that machine?
   / Good bye Green!
The self leveling lift is a little lower at 4200lbs to full height, 3 point is almost 8600lbs.
   / Good bye Green! #7
Congratulations, very nice looking machine.
   / Good bye Green! #8
   / Good bye Green!
How did you avoid that? I also like how wide the front tires are.
Has DEF only and no DPF, the 5609 and 5610 actually have neither which I was thinking about, but wanted more power.
You think the front tires look wide? You should see the rears, lol. Fronts are 480/60R28 and rears are 600/60R38 Michelin Xeobib
   / Good bye Green!
Thanks, I hope it does a lot better then the Deere! The local Massey/Kubota/Fendt dealer has a much better reputation then the John Deere dealer so thats a good start.
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A51692)
2015 Freightliner...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
1995 Ford L8000 Grain Truck GARAGE KEPT (A53473)
1995 Ford L8000...
1995 HESSE CORPORATION BEVERAGE TRAILER (A53843)
1995 HESSE...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
More info coming soon! (A50322)
More info coming...
