Canopy Golf cart cab to fit BX2200 canopy?
   / Golf cart cab to fit BX2200 canopy? #1
149owner
MA
Cub Cadet 149, Kubota BX2200, LX3310, JD LX277
Has anyone found a golf cart cab that will fit over the OEM BX2200 canopy (sun shield) or is sandwiching it under the canopy the only way to make it fit? What are the dimensions of cabs that you have used in either case. Thanks in advance.
   / Golf cart cab to fit BX2200 canopy? #2
149,
See my thread below on BX modifications via TBN.
The plywood roof is 48 inches wide by 58 inches long in the project listed as Cheap Cab.
Also see this thread from a few days ago
web page
Thanks again, Tom! I had read both posts and had it in my head that the OEM canopy was larger then the 58"X48". When I took the ROPS off to fix the wiring and fuel sensor I measured it again and found it was only 53"X48". As George Costanza on Seinfeld might have said- It got cold here, haven't you heard of shrinkage! Anyway, It looks like your cab would fit over the canopy with room to spare.
Hi Tom,
A few more questions questions: You said your top was 48"X58". I went to the Northern Tool site and the dimensions of the deluxe cover you bought are 43"X58" and the next one down are 45"X58". Did your cover have enough give to go 48" or did it bunch up a little on top of the roof?
If any more of our players leave to go to NY you'll be cheering for the NY Red Sox, not Yankees!
   / Golf cart cab to fit BX2200 canopy? #5
149,
The length was a little too long and I ended up rolling up the excess and used large paper clips to hold it to the bottom of the BX. I do not recall the size of the cover I purchased, it was a few years ago.
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2019 INTERNATIONAL...
2024 Kubota RTV-X (A51573)
2024 Kubota RTV-X...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
