Gold weather knock ??
   / Gold weather knock ?? #1
blueriver
Elite Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
Obviously we don't experience as much cold as some others do. Yesterday I had 9 degrees with a good stout wind out of the North so they stated WC at
-2 ... had to put out hay so I fired up the 4340C ... in the shed, a little slow alot of white smoke, a rough few seconds and then she leveled off.
I let her idle while I did the rest of the chores about 20 minutes and then went to the hay ... I know I could hear a faint knock. When you are used to listening to the engine you can hear things that you just don't normally hear.
Neighbor suggested a bad or weak injector ... anyone else care to share your thoughts?
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
