FreeWulf
I'm going to look at a NH TN75 tomorrow morning. Can anyone give me opinions on what I should look out for, and anything I should especially test?
From some of the things I've found online I should look at the rear brake seals. What else?
It has a Synchro Command, and is 4WD. I'm not sure of the transmission gears yet. Any advice on how to test the clutch and transmission?
Any opinions on the tractor model itself? Is it good or bad?
I'll be using it for brush hogging, loading and unloading equipment, and probably taking it with me to Alaska where I'll use it for plowing the driveway.
This will be the biggest tractor I've ever owned. Until now I've been using the communal Ford 4000 backhoe, and a Deere 2020.
