Going to go get my "new" PT 425
   / Going to go get my "new" PT 425 #1
funpilot
Chesapeake, VA
PT 425
Going to go get my \"new\" PT 425
Well, driving now from Virginia Beach to Tazewell to get the 425 and all the attachments that the prvious owner had, plus the 60 inch mower. Probably the trip will cost me $200 in gas.....ouch.
   / Going to go get my "new" PT 425 #2
Re: Going to go get my \"new\" PT 425
When the gas costs more than the attachments, it'll be time to get a mule. /forums/images/graemlinr/tongue.gif
   / Going to go get my "new" PT 425 #3
Congrats!!
Keep us informed and take LOTS of pictures! /forums/images/graemlins/smile.gif
OK, back....so many attachments......hmmm Tried moving something clearly beyond the limits of the tractor using the forklifts. Did not work. It is a former basketball setup with a hug concrete ball at the bottom. Tried smashing its with a sledge hammer....No luck. Any ideas? Pics later.
   / Going to go get my "new" PT 425 #5
</font><font color="blue" class="small">( OK, back....so many attachments......hmmm Tried moving something clearly beyond the limits of the tractor using the forklifts. Did not work. It is a former basketball setup with a hug concrete ball at the bottom. Tried smashing its with a sledge hammer....No luck. Any ideas? Pics later. )</font>
I m assuming that you just pcked up the back end of the PT425 instead of picking up the forks (since the counterbalanced weight of the PT is too low). Make sure that it is as close to the attachment plate as possible.
Is it close to your capacity (ie, can you pick it up with the tractor straight, but then when you articulate the tractor it nose dives?). If so, maybe a little extra weight in the back will help, weight on the rear hicth or someone sitting on the engine cover (careful, it gets hot).
Maybe you can put the forks OVER the concrete base (with the basket support post against the attachment plate), and use ropes looped under the concrete base to the forks. This would move the weight of the basketball setup closer to the COG of the PT425.
2000 Ford F-150 Pickup Truck, VIN # 1FTRX17W7YNA75070 (A51572)
2000 Ford F-150...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
New Long Forks (A53002)
New Long Forks...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
