GMC not charging
   / GMC not charging #1
DarinRay
Platinum Member
West Valley, New York
2004 JD 4310 300CX 72MM, dozers, excavtors, bachoes, loader, tractors.
Hello All,
I know this isn't related topics but hey you guys are a awesome source for info and thought I would throw this past all of you. Please follow my link that I've included which gives details to my problem.
http://plowsite.com/showthread.php?s=&postid=54119#post54119
My question now is that if I have power to the only two wires going to the alternator shouldn't I have charging power at the alternator when running the engine? I really need your help on this for I'm racking my brain bigtime on this one.
Darin
   / GMC not charging #2
Our local NAPA store will bench-test starters and alternators free of charge.
   / GMC not charging
I actually took it to NAPA already and they said it was good but I've also heard that sometimes their machines will not diagnose it properly without getting farther than hooking up wiring harness to it. That's what has me baffled because all they do is hook power up to it and put a load on it. You see I have power to the only two wires that go to it and it still doesn't work. I am confused. /w3tcompact/icons/frown.gif
Darin
   / GMC not charging #4
Check this <A target="_blank" HREF=http://www.autosite.com/garage/encyclop/ency11a.asp>article</A> out. It has a step by step troubleshooting guide.
   / GMC not charging
Thanks for the link. /w3tcompact/icons/smile.gif
Darin
   / GMC not charging #6
The new CountryByNet site has a vehicle section where you might want to post this question. /w3tcompact/icons/smile.gif
   / GMC not charging
Thanks for the heads-up and will probably do that.
Darin
   / GMC not charging
Well here goes....I took the alternator back to autozone to have them test it again because everything pointed to that instead of everything else. This time they said it was bad and not producing NO voltage. HMMMM very good got new one and put it in and presto charging. So after about 4 days of brain draining headache troubleshooting I believe it was the alternator to begin with. The guy there said that they can't test teh diodes and maybe they were the culprit to begin with or whatever.....IT's running now that's all I care about. /w3tcompact/icons/smile.gif
Darin
   / GMC not charging #9
I'm glad it worked out for you. I had the same frustrating experience on '83 Grand Prix I used to own. Brand new alternator and it didn't work. That's when I learned that when it comes to electrical, just becasue it's new doesn't mean it's good.
   / GMC not charging #10
Sounds right, Only the higher end testers can test diodes. When I worked at an independent parts store, they had a $600 OTC tester that would test them. Only catch; Had to bring the whole car with you. It never got one wrong though... /w3tcompact/icons/smile.gif
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2018 John Deere 1653 (A53473)
2018 John Deere...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
SET OF (4) 24.5 ALUMINUM RIMS (A53843)
SET OF (4) 24.5...
