Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Back when I was in school, I had a mid 80's gm car ( pontiac sunbird ). I always was having to use the ecm test port under the drivers side dash to check the ecm codes to fix the car... seems like somehting was always wrong... anyway.. i remember you jumpered two lines,.. then the check engine woulf flash.. like code 12, etc 3 times.. then start flashing the codes.
I had aquired a code page from a mechanic but have long since lost it ( and got rif of the car ).
If I can locate the codes, I would like to pass them along to a friend who is trying to help out a disabled couple, trying to get their 88 pontiac fixed ( running poorly ). He's doing it as a favor as they are more or less indegent. I figure if he had the codes.. he could at least get a start on what they needed as parts.
Any help would be appreciated. If you don't want to post them, email them to me.. my email is as follows:
c.britton@worldnet.att.net
Soundguy
Soundguy
