Glow Plugs
/ Glow Plugs #1
massey184ferguson
Bronze Member
Atlantic Canada
Massey Ferguson 184-4
Does anyone know how I can see if my tractor has glow plugs? What to look for etc. Got the tractor used and never really knew
/ Glow Plugs #2
As you're in a hurry, try posting here, for better traction:
Massey Ferguson Owning/Operating
Don't know your model, so here's a general answer:
Diesels will use either Glow Plugs, or Intake Heaters, and possibly both on a given engine.
Glow plugs (the back end) usually look something like mini-spark plugs, installed near where the fuel injector line goes into the head. Wiring to them typically looks like a regular 12v automotive wire (as opposed to spark plug wires). One per cylinder.
Intake heaters sometimes have a heavy metal stud sticking out of the intake, with pretty heavy 12v wiring hooked up to it. Depending on design, it may be connected with a hefty connector instead, with the same heavy 12v wire connections.
If you don't have the Operator's Manual, try the MF site, they should have one available there. The factory manual should clearly indicate what type of cold-start system you have, and how to properly use it.
Rgds, D.
/ Glow Plugs #3
On top of the engine (more or less) look for three or four devices that look like spark plugs (more or less). Instead of plug wires they are all connected together with a "buss" of a strip of thick metal going back to a heavy duty relay.
/ Glow Plugs #4
I have the 3 cyl version of your 4 cyl Perkins. Mine does not have glow plugs and is a little hard to get started if left in the cold. I am looking at adding a block heater just to make it a little easier to start when cold.
