NH 1630 W-7308 FEL/ Kubota L4630GSTC W-LA853 FEL WQ/A-CC 2544
Check your ignition switch, when starting the tractor, the key is not returning to the on postion by itself. By turning it back manually to this postion, the glow plugs will not seem to come on during operation.
Had this happen to my 1630 this summer after about 500 hours and this was my cure, do not know if the switch is dirty or needs to be replaced.
If you are using a key with a rubber shield, get rid of the shield. There is a real metal key under it. That key was introduced on the Class III's and is okay there, but on the new Class II's with that key/switch the rubber doesn't allow the key to return completely to 'run' from 'start'. All manner of wierd stuff happens.
Okay, I'll check into that. I've had the rubber thing make the key stick so the starter keeps running, but I didn't realize it may be sticking without the starting cranking.
2019 Rural King RK55HC with Loader & Backhoe; 2001 New Holland TC40D with Loader
Mine comes on occasionally, enough that I got out the service manual and skimmed the trouble shooting a couple months ago. I suspect the glowplug timer or solenoid in mine (TC40D). I don't use my rubber key either and am sure the switch returns to the run position. It hasn't happened with enough frequency and duration to bug me, but I do want to get it fixed before the powertrain warranty expires next April.
How good are you at reading electrical schematics?
I'm guessing 1 of 2 things is wrong:
switch is sending a "false positive" (closing the circuit = on) to the glow plug solenoid or the solenoid is malfunctioning to closed (on) when it should be open (off).
Check the terminal on the switch that goes towards the glow plug solenoid for voltage or follow the wire to the solenoid and check there. When you are in the "run" postion, you shouldn't get any. Wiggle the key around a little, also wiggle the wires around a little to see if you get +12V at the switch.
That ought to eliminate the switch as the culprit.
To check the solenoid, I'd remove it and cycle it a few times to see if it is returning to "normally open". There might be a resistance check or something else you could do (not sure).
I don't have your schematic in front of me, so my advice could be wrong... Good luck.
