Glow plug relay
   / Glow plug relay #1
CarlHark
Hinomoto E2802
Can anyone tell my the location of the glow plug relay for a Hinomoto E2802?
   / Glow plug relay #2
Can't say where but might suggest that activating it you should hear a solid click or clack as being a high current device it would announce its presence.
   / Glow plug relay #3
I own a E-230 and there is no relay, it works right off of the 12v going to key switch, I have the wiring schematic, and it does not show a relay, but its not a E-280 so not sure about 280, but my operators guide does cover both.
   / Glow plug relay #4
Fall back solution is follow lead off glow plugs back to where ever it goes, it will eventually terminate on relay or key switch....
   / Glow plug relay #5
Your tractor may not have a relay. Many Japanese tractors of that vintage used a dropping resistor to drop the twelve volt power to the 10.5 volts the glow plugs use. It took the form of a kind of glowing indicator, usually a round thing with holes, on the dash. Inside is a short coil of nichrome wire which gets red hot when activated though you may or may not see this action. Over time the terminals tend to corrode or oxidize and you may no longer have adequate current to power your glow plugs.
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
M & M Grain Drill (A50515)
M & M Grain Drill...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A52128)
New Lewis Brothers...
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
