glow plug relay
   / glow plug relay #1
boxorox
jax fl
shibaura s1500/kuboto bx2200/
My 1983 6.2 litre suburban glow plug relay went out so I put a new one in yesterday it wrked at first and then the light stayede on too long and now it wont click on could something else cause this or should I take it back to napa as it was a lemon.
   / glow plug relay #2
Similar issue o my 87 right now. There is a temp sensor that is in the cross over pipe that can go bad and tell the controller to stay on.
But, you are better off disconnecting to power to the controller and using a relay and a non- maintained switch to power the glow plugs. This will require you to manually activate the glow plugs, but its more reliable. This mod is done often and can be found in all the GM diesel forum sites.
   / glow plug relay #3
Been there also.
Any good relay activated by a push button switch and count thousand and one, thou and 2, thou and 3 worked for me. If it did not start after 3, I'd repeat and go to 5. (at-30 I'd simply go to -5)
One guy simply had the 2 leads under the dash and touched them together and counted, but then he was Mr good enough!
JOHN DEERE Q 850 M LOT NUMBER 226 (A53084)
JOHN DEERE Q 850 M...
NORTHERN 3P-100 AG MIST SPRAYER (A51247)
NORTHERN 3P-100 AG...
2019 Cat 914M Wheel Loader (A52384)
2019 Cat 914M...
2002 Chevrolet Silverado 2500 4X4 Pickup Truck, VIN # 1GCHK29UX2Z216239 (A51572)
2002 Chevrolet...
2022 John Deere HD45F Draper Head (A53342)
2022 John Deere...
