Thanks It is a L4310HSTC. 2003
I pulled it into the shop to replace a steering hyd line to the cylinder and now it wont start. It has been turning over slowly for the last couple of months, but it is winter here and I attributed that to the -25 weather. I found a slightly cracked wire from the fuse (near the starter) to the starter.
When I try to turn it over, the glow plug relay makes a weird noise for 1 second. Kind of buzzing. This is when the glow plug light shuts off.
I unplugged the large power wires on the glow plug relay and the relay works great. When I re-plug the wires in, the dash light get dimmer and the buzzing happens again.
On turning the key further, there is no starter movement at all.
I tried to jumper the starter at the 2 terminals on the starter and it does not move. I pulled the starter and it engages and spins properly on the bench. I now think this is the slightly broken wire.....but not sure.
The next test is to jumper directly from the battery while on the machine.
I also thought the glow plugs would be independent from the starter circuit, but now I have starter and glow plug issues. Sound like a power issue. I grinded the ground strap connection but that did not help.
Should I be looking at replacing all positive wiring from battery .......>?? Why would the glow plugs be giving me issues./?
Thanks again....
