Glow Plug Question
   / Glow Plug Question #1
Underdog57
Veteran Member
W Michigan
LS R4041H
Is there any harm to the glow plugs or the engine if I cycle the glow plugs 2 or 3 times before I start the engine when it is cold. I have been cycling them twice in this cold weather (15-20 degrees) and I think it really helps. The engine starts easily with not much smoke or knocking. I have lots of experience with Diesels but none with glow plugs. Thanks
   / Glow Plug Question #2
I do it too, with my LS, my current Hustler ZTR, my previous Kioti, and my previous Ford commercial mower (when I snow plowed with it).
I also think it helps, and I can't imagine any reason why it would cause harm.
   / Glow Plug Question #3
I have read that it shortens the life of the glow plugs, but like you I cycle them a couple of times when it is below 20deg
   / Glow Plug Question #4
I cycle my glow plugs a couple of times when it is very cold...
It helps with the cranking...
Here in NC that is not too often...
I would think that it would shorten the life somewhat but I would not worry about it...
To me it is better to help in the starting when cold...
   / Glow Plug Question #5
I tried two cycles on them this morning (30*F or a bit less) and did notice less smoke, and that it got to a smooth idle sooner.
   / Glow Plug Question #6
exactly what I found this morning when I cranked her up to plow the driveway, it was about 20 deg. Much smoother start with less smoke.
I've heard that they are cheap & easy to replace??? Anybody know what they cost? Just curious are they easy to replace on the Mitsubishi? I don't anticipate ever having to cycle them more than twice, so I don't think I'll ever have a problem.
   / Glow Plug Question #8
I have had minus 30degree C here the last couple of weeks - only cycle my 4041 once (have rad hose heater as well) but have found the semi-synthetic 15W40 a big difference ... no ping at all.
   / Glow Plug Question #9
The manual for my Dodge Ram cummins diesel suggest 2-3 cycles in very cold conditions. Although it has a grid heater (no glow plugs) like my John Deere, so it is only heating the Intake air. I actually hold the glow plug (grid heater) on for a bit after the tractor starts to help heat the intake air in extreme cold conditions.
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
(INOP) 2005 JCB 506C TELESCOPIC FORKLIFT (A50459)
(INOP) 2005 JCB...
2017 Polaris 500 Ranger Diesel (A50324)
2017 Polaris 500...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
