glow ignition question
   / glow ignition question #1
rlee6
Central Florida
Allmand 8435 HST (TYM T330 HST)
My Allmand 8435 HST has glow ignition time set for ~10 seconds. Instruction manual says that once it is triggered, wait until the light goes off and turn on the engine. My question is this: What happens if I turn on the engine before the light goes off? Will I be ruining something? Or am I just not taking the full advantage of glow ignition? Thanks.
   / glow ignition question #2
the glow plugs will always run the same amount of time even if you start the engine . If the engine has been run ,and is still warm you can turn the key to the right to start without glowing. Nothing will be damaged if you do anway. happy tractoring.
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2012 Ram 5500 Service Truck, VIN # 3C7WDMDLXCG124340 (A51572)
2012 Ram 5500...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
