Glo plugs: no go on the glow
   / Glo plugs: no go on the glow #1
thebudman
When I try to start my Nor Trac 254, and I turn the key to the "heat"/glo-plug setting, I notice the amp meter no longer jumps-- in fact, it doesn't move at all. Since it now take forever to start the tractor when it's cold, is there something wrong with the glo-plugs? If they are the problem, how do I go about fixing them?
   / Glo plugs: no go on the glow #2
Is the 30 amp fuse good?
   / Glo plugs: no go on the glow #3
If your other electrical devices work, it's not the system fuse. Some Jinmas (NorTrac is a rebadged Jinma) have a separate fuse for the glow-plugs. I think it's labeled HEAT or PRE-HEAT
//greg//
   / Glo plugs: no go on the glow #4
if you have any electrical savvy it is a pretty easy check. Use a meter of 12V test lamp and while someone is holding the key probe the metal bus bar that connects the injectors together and see if voltage is present. If it is, check you plugs for open condition. If it is not, back track to see where you loss of 12v is. But like others said, start with the fuse
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2016 Kubota SVL75-2 (A50123)
2016 Kubota...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
AGT Mini Excavator Attachment Set (A50123)
AGT Mini Excavator...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
