GL 3540 -50 hour service.
   / GL 3540 -50 hour service. #1
lawn_king
Veteran Member
Hanover massachusetts
kubota L 3540 hsdc,B 2320 hsdc & lots of other stuff!
I will soon be due for my break in (50 hour) service. I have done this service myself on my last 2 machines (B7500-B3030). The 50 hour service on the 3540 calls for adjustment of the clutch, im not qualified to perform this adjustment. My question is, how much adjustment could the clutch really need after just 50 hours?
   / GL 3540 -50 hour service. #2
Page 92 of owners manual describes procedure for adjusting clutch free travel. (20mm ~ 30mm / 0.8" ~ 1.2") If clutch free travel is within spec, no adjustment is needed.
   / GL 3540 -50 hour service. #3
The manual is pretty good. Just follow it. A few oddities like 2 engine oil drain plugs, Have to remove a plug to grease the front axle pivot, Fuel system is not self bleeding. But it is still a very simple service. I recently completed the 200 hour service. :)
Kevin
   / GL 3540 -50 hour service. #4
Mine has required NONE after 250 hrs.:) This adjustment is very easy though. You just kneel down on the clutch side and depress the pedal until you feel some resistance. The distance the pedal moves is the spec. So it kind of helps if someone holds a ruler next to your pedal so you can more easily depress the pedal to feel the resistance.
So ask your wife to kneel down by your tractor holding the ruler, while you sit in the comfy seat and depress the pedal. Then take her out for a really nice dinner, so you don't end up sleeping with your tractor for a week, or two :eek:
BTW the true procedures/costs of maintaining a tractor are not in the Kubota manual :)
Talon Dancer
   / GL 3540 -50 hour service. #5
[ (BTW the true procedures/costs of maintaining a tractor are not in the Kubota manual :)
Talon Dancer[/QUOTE]
What do you mean by that? Have you had problems with yours?
Bill
   / GL 3540 -50 hour service. #6
la200o said:
"(BTW the true procedures/costs of maintaining a tractor are not in the Kubota manual :)
Talon Dancer"
Bill
One of the costs of maintaining a tractor that s not in the Kubota manual is -- dinner for the wife after she helps you :)
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
UNKNOWN UTILITY TRAILER (A50854)
UNKNOWN UTILITY...
2013 Nissan Altima Sedan (A48082)
2013 Nissan Altima...
2016 Cadillac ATS Sedan (A48082)
2016 Cadillac ATS...
2022 Club Car...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
