Gizmo Plans 3 Cubic yard Cement Mixer
   / Gizmo Plans 3 Cubic yard Cement Mixer #1
hotrod45
Saskatchewan, Canada
Case 830
Just wondering if anybody has built this cement mixer or knows of anyone who has? If so how does it work and the cost?
   / Gizmo Plans 3 Cubic yard Cement Mixer #2
I did a lot of thinking and research awhile back on building one that would be able to mix 3 yards at a time. I thought about all the different ways to mix the batch and finally settled on one that would stir the mix in a round medal tub with an extraction port on the bottom. Actually with this type you would not be mixing the whole 3 yards at one time but once you got the batch going it would be a continuous flow of mixed concrete available at the extraction port as long as you kept feeding the machine.
This type would be good for a site that you could not get concrete to or didn't want to have to pay a pump truck. Two guys feeding sand, gravel and powder would keep three guys with wheel barrows busy as long as they all had the gas to keep going.
I was going to run the one I built off of hydraulics but you could run it off of a gear reduction box if you could figure out just what gear you needed. I had more access to hydraulic components so I wanted to go that route. I built a small batch unit and used an old jonny rude outboard lower unit as a gear box and it worked quite well but I never could get the speed just right. The gear ratio of the lower unit was too high for the power unit I was using, a 8 hp gas motor and I played around with adding a pulley reduction setup but before I got it going I started building my pole barn and I haven't had time to mess with it anymore.
A lot of people beat me up about this topic back when I asked this same question saying it was a waste of time and you would never get good quality cement out of such a machine but if you have the time and desire I say go for it.
   / Gizmo Plans 3 Cubic yard Cement Mixer #3
Projects are fun but I've poured enough concrete that I know it's a lot of hard work to just grade and finish it. Add the mixing to that and it's a man killer. I'd call Ready Mix and save my dough for a more useable project.
   / Gizmo Plans 3 Cubic yard Cement Mixer #4
Not to mention the fact that just mixing Sand , Rock, cement powder and Water, wont make a lasting mix , If outside and you are subject to freezing temps during your year, you will need air entrainment .If you are just talking about making a mix for post holes or footings then you would be OK.
Rubbermaid Water Trough - 100 Gallons (A55218)
Rubbermaid Water...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
2016 FREIGHTLINER CASCADIA DAYCAB (A53843)
2016 FREIGHTLINER...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
