rback33 said:
Come on Brian.... let's here it.... Where are you???
Believe it or not, I do have to work once in a while.
OK, there are a few things that I don't care for on my 7520.
#1 The draw bar is to low, but I believe that flaw has been rectified in newer models.
#2 The cowl head lights are pretty much worthless, don't aid in being able to see and have burned out twice, don't need to hit me over the head 3 times, no need to replace them again.
As far as my tractor, that is it as far as design flaws. Now I have had the radiator over flow bottle crack
and I replaced that and the steering actuator had a nut come loose and I had a bad oil leak from that.
But I just tracked the source down and tighten the nut, No more leak.
Now Mahindra has changed a few things regarding the new 7520. Some of the stuff that was standard on mine is now an option.
The pto is now 1 control lever instead of 2, and I think that the tractor is a few inches longer to accommodate the newer style engine.
I have not kept up with all the tractors to date,
but when I bought mine back when they had first come out and I believe that even today( but not positive) I would gladly put a Mahindra 7520 up against any other make and model of the same horse power to see which tractor is stronger and can do the most work. I don't think that you can find one that will do more, maybe as much, but not more.
In your search, look for a tractor that fits you, what I am trying to say is find a tractor where the controls are in a natural location for you to use and the tractor is comfortable to sit on. Enough of my rambling, these are all just my opinions and they don't count all that much.
