Giant Vac Field and Brush mower
   / Giant Vac Field and Brush mower #1
Don Smith
Branchport, ny
I just bought a Giant-Vac field and brush mower, model GM2513BS. It has a Briggs 13.5 HP engine It is also sold under Snapper, Ferris, Simplicity. I think Briggs and Stratton owns most of the mower brands now. I have used the mower for 8 hrs so far, and it is Great. I did look at the DR and Billygoat. The mower has a hydrostatic drive which makes it very to use, however it does require some strength to use it such as turning.
   / Giant Vac Field and Brush mower #2
Welcome to TBN Don.
That is a serious looking mower.
Are there skids each side to maintain cutting height?
Is the vertical shaft engine direct coupled to the input shaft on the hydro?
That lake near Branchport looks beautiful, I assume it is natural but it is surprising as there doesn't appear to be any mountain ranges between this lake and others in the area.
allenr,
You asked Is the vertical shaft engine direct coupled to the input shaft on the hydro? It is belt driven.
There are skids on the sides of the mower that allow a cutting height adjustment from 3 to 4.5 inches
   / Giant Vac Field and Brush mower #4
Giant Vac used to be here in CT,South Windham at the old Smith & Wesson plant. They made some great products,many of which are now simplicity...I think. We have a giant vac walk behind mower thats hydro,that mower can really move some grass,and built like a tank.
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A53473)
2020 Massey...
Year: 2018 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 225,027 Plate: Body Type: 4 (A51692)
Year: 2018 Make...
2003 Peterbilt 330 T/A Progress A90LS 4,500 Gallon Fuel Truck (A51692)
2003 Peterbilt 330...
UNUSED GREAT BEAR 78" HEAVY GRASS FORK GRAPPLE (A51248)
UNUSED GREAT BEAR...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
