Getting the rear remote to work again
   / Getting the rear remote to work again #1
Rod in Forfar
Platinum Member
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
Last week I bought a used 3pt hitch block splitter, brought it home and hooked it to my TAFE 35DI. It has a pair of remotes described in the manual as a tipping lever.
It wouldn't work, so I took it to my neighbour. He tested the line and found pressure, then monkeyed around with it until the thing worked strongly, if a little slowly. Delighted, I split a pile of elm blocks, then used the loader (another setting on the three-way splitter) to haul some of the wood to the garage.
A couple of days later I decided to split some more wood. No response from the splitter, though the other two settings work well for the loader and the 3 pt hitch. I have tried every combination of settings at least a dozen times. Could the thing have a vapour lock, and how would I bleed it?
The reason I suspect something like that is that when my neighbour used his meter on the lines, things improved.
The tractor has 480 hours on it, a 1995 in pretty good condition. I have had no trouble with it in the year I have owned it.
Suggestions?
My neighbour came over and set me right with his pressure gauge. My misconception was that there are three settings on the three-setting diverter valve on a TAFE. There are only two: 3 pt hitch, auxiliaries, and OFF. The tipping lever (rear remote) works off the same circuit as the front end loader. Time to buy a pressure gauge, I think.
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2015 Ford F-150 (A53422)
2015 Ford F-150...
