Getting the machine home
   / Getting the machine home #1
irwin
Veteran Member
SE Conn
2004 Kubota L35TLB, '89' Cub Cadet 1541
Just thought I'd relate my experience getting a Kubota L35TLB 380 miles. Bought it after finding it on line, made the seller promise not to sell it until I drove down to looksee, I kept in touch while driving down in the gas sipper.
It was just what I wanted.... 2004 with 272 hours, set up with QA loader with 3rd function and pushbutton joystick control, softside cab w/heat, two backhoe buckets one a 12" trenching with QA on that end also. Came with a tiller and a snowpusher.
I didn't want to use my truck and too small trailer for obvious reasons, the TLB w/cab and QA weighs 6000 plus pounds and has a couple heavy extras, overloaded on the trailer weight "7k 16 foot".
I found a shipper and hired him.. The waiting began. Finally moving day, at 7pm got a call he loaded it up and was on his way, expect him at 3:30am, he asked that I call him when I went to bed so we could set up a drop off time. At 10pm I called........................
His response, "well there's no rush now I'm broken down in the middle of I95 about 50 miles from the pickup location" he also told me he'd been trying to find a trucker friend to come down the finish the delivery so he could concentrate getting his new Dodge dually to a dealer for warranty repair of whatever the problem is. .....Well this s**ks I thought.
I thought for a few minutes after hanging up the phone, then called him back, told him I'd leave immediately and meet him, seems he got it running barely, and made it to a motel, i got directions and loaded the trailer on got a friend to come along and left at 1:15 am, we drove down, ... I'm in my 50's and I worked all day and was now embarking on a 14-16 hour round trip.
You could say I was a little worried about the weight issue and would my older truck (94 GMC K2500) be ok for this job. driving slower than usual we made it to the motel (my friend and I shared driving down) at 9am, got the loose attachments in the picup bed and loaded the tractor and chained it down.. the next 7 hours were somewhat anxious, but mostly uneventful, made uncomfortable because I was unable to use the ac, the temp gauge moved to hot when I tried, It was hot and sticky that day. The trip was full of exhaustion and discomfort, a rich tale for another time.
Well I made it.... all's well.
   / Getting the machine home #2
Good story! Thanks for sharing.
It's good to see your "new" tractor home safe. I assume you won't be using the GMC to move this tractor around much but I would be worried about the overheating issue. My 03 1/2 ton can tow 8,900lb so I bet an older 3/4 ton could pull at least that and your load seems to have been around 7500lbs. Maybe it's time for a coolant flush.
   / Getting the machine home #3
Good to hear you got it home after all... When i brought my 3011 home, i used a 7k trailer behind my 850 TDI, to pick up that 3500 lbs tractor at 110 km/h. It is rated for 1600 kg (3200 lbs ?) towing, but the Diesel easily tows twice. This 2.5 TDI engine, originated from VW, is used for 7 ton gross combination weight in the Volkswagen LT 46 van.
Or time for a head overhaul ! overheating engines are usually caused by leaking exhaust valves.
Nope, just had a flush but needs a radiator, getting a bit slagged up in there. I'll add a aftermarket oversized trans cooler, also needs a new fan clutch. It ran great. Was only when I added the stress of the compressor did it get too warm.
I bought it last year for almost nothing, only after I checked the compression and did a leak down check, it's a good engine, but anything's possible.:eek:
I sure am glad it made it back with the engine as smooth as it was when I set out. Anyway the Kubota's worth a lot more than that old truck..:D
   / Getting the machine home #5
That's a great story, and a nice looking machine. I'm sure it was worth it to you now that your home and going to work. Its always good when there's a happy ending. Good luck with the Kubota.
I'm a sucker for a happy ending ... I enjoy reading tales of success, glad I had a chance to write one.:D
   / Getting the machine home #7
Congrats on your "new" tractor !
Having done similar transporting in a previous life, i'm well aware breakdowns happen even on new equipment...... usually at the farthest point from home.
I'll bet it felt good as you turned into your driveway !
The closer to home, the better I liked it. You're right though, in the driveway was the best. I figured if only the police could stay pre-occupied while I passed through their area... I'd be good,, really I would, was planning a 10k trailer purchase the whole way.:D
On a related subject, I ordered a W.R.Long open bottom grapple yesterday. Was told I'd see it in 3 weeks or less. OBG
7022 (A50322)
7022 (A50322)
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
80in HD Tooth Bucket with Side Cutters (A52748)
80in HD Tooth...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A52576)
2023 EAST TEXAS...
1992 JOHN DEERE 544E WHEEL LOADER (A52472)
1992 JOHN DEERE...
