Jaybr
A couple weeks ago while my son (20) was running the wood chipper on our CK35, the hydraulic pump sprung a leak. The tractor is just under 2 years old, and less than 200 hrs on it.
I called my dealer, they came and picked up the tractor, and over the past 2.5 weeks have replaced several different o-rings in the pump, and each time it blows another.
This morning I get a call from them telling me that they just realized that the rear remotes where engaged, and that was causing the problem. They also stated that since every time they started it up to test it the pump got extremely hot, that Kioti says they need to replace the pump as damage has been done.
Here is the kicker, the dealer says that Kioti will not cover this under warranty because the remotes where engaged which burned up the pump.
I know when I checked out the problem, the remote lever was in the neutral position, I haven't had the backhoe on the tractor since last summer, and I know the lever has been in neutral since.
The dealer says that Kioti sent out a bulletin stating that if there where pump problems and the tractor had rear remotes, they would not cover under warranty because it could have been caused by operator error with remote engagement.
I never got that bulletin, and my warranty says bumper to bumper for 2 years, powertrain (pump should be covered here) for 4 years.
It seems to me that if there is no releif valve in the system to address this it is a very poor design.
It also seems very fishy to me that I know the remotes where in neutral, and now they are engaged. Also fishy is that my dealer dropped Kioti last year, but still does warranty work, and maybe Kioti doesn't want to support them and their just looking for a way to get me to foot the bill.
I will fight this and fully expect Kioti to fix this under warranty.
