Buying Advice getting ready to buy
   / getting ready to buy #1
dc53
cicero,new york
power trac 425
hello,
been following the pt forum for a while so i feel like i know some of you.
getting ready to buy a 422 or 425.
also would like to know if I can put the machine with one attachment connected on an 8 ft bed.
I have ram 1500 and will get a 2500 w/8ft bed or 3500 ram w/9 or 10 ft flat bed.
any input will be appreciated,
thanks,
Dan
   / getting ready to buy #2
Welcome to TBN! :thumbsup:
I have a 2001 model year PT425. I do not know if it is the same length as the current models. I also purchased the metal ramps from Power Track at the time of purchase.
I frequently carried my PT425 with an attachment in the back of my 8' bed on my old Chevy pickup truck. HOWEVER... I removed the tailgate and put a mounting system for the ramps on the truck bumper to make it secure. I welded a piece of steel tubing to the bottom of each ramp and welded another piece of steel tubing to the steel truck bumper. Then I could secure it by sliding a piece of rebar through the pipes and it acted like a giant hinge. Worked great, but not very attractive. Whatever you do, just be sure the ramps are secured to the truck so there is no chance of them slipping off the rear bumper and dropping you to the ground.
I did not trust those little straps that hold the tailgate with my multi-thousand dollar investment, that's why I removed the tailgate. It is easy to do and requires no tools (at least on mine).
I then backed the PT up the ramps and into the bed of the truck. By backing it in, you can keep an attament on the FEL arms. I've hauled the 60" finish mower OR the 48" brush hog, OR the large light material bucket with the small rock bucket with teeth nested in the large bucket and put the pallet forks inside of that. No matter what attachment I had on, I could rest it on the rear of the truck bed and back bumper.
   / getting ready to buy #3
Eventually we retired the pickup due to rust and bought a car hauler trailer for the PT and all attachments. We towed it easily with a van and now a Suburban. :thumbsup:
   / getting ready to buy #4
What implements will you be carrying? I am sure a 425 and bucket will fit but don't think a 425 and mower will. Plus if you air taking multiple implements I would go for a low trailer. Get a 425 btw. And if youth do go w itch a truck and ramps be careful...
   / getting ready to buy #5
Read my previous post. A PT425 will back right up into a full sized pickup truck bed with a 60" mower deck attached even with no tailgate on the pickup truck. I did it frequently until I bought our trailer.
   / getting ready to buy #6
And I will caution once more the importance of not using the tailgate and securing the ramps to the truck so they can't slip off.
   / getting ready to buy #8
On my Chevy 2500 I carry my 422 with the brush hog, or the bucket, or the mini-hoe with no problem. I can even carry the mini-hoe in the bucket and load that on the pickup, backed in like MossRoad suggests. If I need to have more implements I insist that whoever I'm doing the work for come with their truck to carry implements.
I leave the tailgate on and position the front tires so that they straddle the crack between the tailgate and bed to keep the tailgate from bouncing. That also gives a good clearance in the front of the bed. I have a fifth-wheel hitch rail that I tie the PT to.
Mine's a '91 and has metal straps for the tailgate. I have a newer F250 that has the crimped cables to hold the tailgate and I would be reluctant to put a lot of weight on it for fear the crimps would fail. But I don't use it to carry the PT since I have the Chevy for that.
I use the cargo straps that hold the PT in place to also hold the ramps in place when I'm loading or unloading.
ONE TIME I tried not using the straps to hold the ramps while unloading the PT. When the weight of the tractor was off the pickup, it rose up and the ramps were within 1/4" of slipping off of the tailgate edge. I DID have a friend standing there, so at least someone would have been able to dial 911. It was an experiment that failed, and now I NEVER load/unload without strapping the ramps.
Phil
   / getting ready to buy #9
I am so sorry. I just read my most recent post and it is clear I have to give up the Ipad. I cannot type on that thing for.....
   / getting ready to buy #10
I will take if you need to get rid of it. You have to pay the shippiing and it's free, right?
Sent from my IPad.
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
2017 International Prostar Sleeper Truck Tractor - Cummins ISX 15 Engine - 10 Speed Eaton Fuller (A53472)
2017 International...
