butternut
I got through most of the 50 hour maintenance on my 2320, except the HST filter and the fuel filter. The HST filter is wedged into a tiny little square space behind the loader frame. No way to to get a strap or band wrench in there. I guess I need a jaw or end cap wrench, come up straight from underneath? What do you guys use? And the fuel filter... I assume you turn that notched metal collar, under the valve. With what? It's also wedged tight against some fuel lines and the body of the tractor. There is a little room to come from the side, and underneath I think. I tried a plumbers drain wrench. Do you use wrench pliers of some kind? It seems pretty tight. Is it ok, to really torque it?
PS About the fuel filter replacement. Turn the valve back on, the bowl fills up, and that's it? Do you need to disconnect a fuel line and bleed it?
