Getting my butt kicked power issue
   / Getting my butt kicked power issue #1
Brokedownbobcat
Bobcat ct230
Bobcat ct230 no power anywhere. I have power at the starter, nowhere else. I have checked continunity on all the saftey switches, and all the fuses test good. No power anywhere else. Have cleaned the battery post, replaced the cable ends. Was running fine, parked it, now nothing.
   / Getting my butt kicked power issue #2
How long was it parked? Mice/rodents love to chew wires. Look behind/under the fuse/relay block.
Im trying to unzderstand the power flow, because i pulled the main fuse by the starter, no power their either.
   / Getting my butt kicked power issue #6
Possible there is a break in the wire or a bad connection between wire and wire ends. Can you disconnect the wire in question and check for continuity with a volt ohm meter.
Would also confirm ground from engine to frame and electrical console - dash to frame.
Depending on where you are checking voltage to ground that could also be a problem.
   / Getting my butt kicked power issue #7
Is there a fusible link ... blown?
I dont know which wire, because the only power i have is where the hot hooks to starter.
I have pulled frame ground off and cleaned it all
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A56129)
2020 KENWORTH T680...
2018 Altec DC1317 Towable Brush Chipper (A55787)
2018 Altec DC1317...
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
