Getting diesel in tractor
   / Getting diesel in tractor #1
tld
Boston, GA
JD 2025r
I have JD2025 and am really tired of climbing up with a 5 gallon can of diesel and pouring it in. Sooner or later I'm going to bust my butt.
I don't use it enough to warrant
A tank and fuel delivery.
Any ideas?
   / Getting diesel in tractor #2
I got a 100gal tank at Tractor Supply, bolted it to a pallet, added a 12v pump,filter,,battery,extra hose, and sat that on a dolly. Pick it with the forks, sit it in the pickup,fill at the station and bring her home. You could make up something with a smaller tank, now you just need to get some more diesel toys !:laughing:
   / Getting diesel in tractor #3
   / Getting diesel in tractor #4
If you typically don't use a lot of fuel, you can get a simple hand pump and pull it out of your current 5 gallon can. You just don't need to lift it anymore. If you want to get more fuel at one time, you can look for a poly drum. You can get a 55 gallon size or smaller 12-30 gallon sizes depending on your needs. The small pump I got I bought at a garage sale for $5.00. You can get bigger hand pump or a small 12V model for $50.00-$150.00. If you want a top notch pump, you can get one made for the fuel transfer tanks. Those are $200-$400.
I was going to use a transfer tank from a pick up truck with a 12 volt pump but found it was much bigger than I really needed. I had an old 30 gallon drum. For now I use that hand pump, but I will replace it with a better pump when I get a chance.
There are quite a few treads on this subject so a search should bring you a lot of pics and descriptions. There are some guys on here that have done a really good job of making a tank with pump and dolly.
Good luck
John
   / Getting diesel in tractor #5
A 12 volt fuel pump and a couple hoses
   / Getting diesel in tractor #6
I was given a nice clean 55 gallon drum by my former employer and friend, I filled it for the first time last week. It has a cheesy plastic hand pump that works for now, but I plan to sit it up higher than the tractor and let it gravity feed the fuel tank.
   / Getting diesel in tractor #7
I second the KevT method. Mine is 15 gallons with about a 15' hose and a regular gas pump type handle. Carry it to the station in the back of my truck to fill. Then unload into the FEL bucket, lift it up to about 8 or 9 feet high, and let gravity do its thing. Takes about 4 or 5 minutes, with no heavy lifting or juggling required.
   / Getting diesel in tractor #8
Purchase small transfer pump couple hoses.
   / Getting diesel in tractor #10
I've got a JD CUT and don't use a ton of fuel. I keep 3 5 gal cans on a special shelf beside the tractor I made when I built the tractor shed. Then I bought a simple shaker siphon hose, remove the large tops on the cans, insert the hose, put the other end in the tractor tank and shake a second. The diesel fuel drains quickly and I can fill the tank in just few moments. All I had to do is lift the can to the shelf. You can get shaker siphon hoses at TSC sometimes, and other farm/hardware stores. I also keep a roll of paper towels by the tractor to wipe up the sometimes spill and to wipe off the hose to keep it clean. Works well and it cheap.
UNUSED GOLD MOUNTAIN M202010 20'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51247)
UNUSED FUTURE BOX...
2019 Dodge Ram 5500 Tiger Crane 6545EP 6,500lb 3 Ton 4x4 Crane Mechanics Truck (A51692)
2019 Dodge Ram...
(2) UNUSED 3500# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 3500#...
2012 Scion Xb SUV (A51694)
2012 Scion Xb SUV...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
