Getting a Yanmar repaired
   / Getting a Yanmar repaired #1
Fredster
North Alabama
Yanmar FX24D
I'm pretty clueless when it comes to machinery, so this may be a dumb question.
While cutting my field tonight, the main belt in my engine case broke (model: FX24D). There's probably a name for that belt, but I don't know what it is. It connects the fan behind the radiator with a couple of other things. When the belt broke, the 'charge' light came on, so I figure if there's an alternator on the tractor, the belt was connected to that, too. Again, bear in mind that I don't even know enough about what's in there to be dangerous. I'm lucky I identified the broken thing as a belt.
My question is this: I bought the tractor from Fredricks, who is about 20 miles away. I don't have a trailer to get the tractor to them. I know they'll come pick it up if I want them to, but I figure it'll cost me an arm and a leg to have them do that. There's a CASE dealership about 1 mile from my house. Should they be able to replace the belt for me, or should I only take my Yanmar to Fredricks?
Thanks in advance.
   / Getting a Yanmar repaired #2
Thanks in advance.
That's called a "fan belt" and is a very simple matter to replace. If it was me, I'd take the broken belt in to just about any auto parts store, get one the same size and replace it. That will undoubtedly be much less expensive than getting a mechanic out to the tractor.
In any event, don't run the engine for any extended time without the belt. The fan won't provide any cooling air flow through the radiator, and if there's a water pump on your engine, coolant will not be circulated. The engine will overheat very quickly and then you could really have a problem.
To install the new belt, you'll need to loosen the bolt(s) holding the alternator so that it can be pivoted inward to allow room to place the belt around the pulley on the fan/waterpump, the big pulley at the bottom (crankshaft), and the one on the alternator.
Once it's around all the pulleys, and with the alternator bolts loose, pull outward on the alternator (probably need a short pry bar) putting tension on the belt - should be able to deflect the belt 1/2" or so with moderate finger pressure. Then tighten the alternator bolts, recheck the belt tension, and you're done.
   / Getting a Yanmar repaired #3
Thanks in advance.
The belt is an A39.
Danny
   / Getting a Yanmar repaired #4
Fredster,
Where are you in N. Alabama? I'm in Rogersville, Maybe I can help you.
Send me a PM.
   / Getting a Yanmar repaired #5
Eddie said:
Fredster,
Send me a PM.
YOU the man, Eddie!
We all assume changing a belt is simple....but IF you've never done one before It might be a challenge. If I had never done one before I'd want to watch someone or get a little instruction.
Fredster, IF Eddie, or any other competent mechanic shows up, seize that moment and find out as much as you can concerning air filters, fuel filters checking the oil and other maintenance issues you Must perform. Somehow I just have a feeling that you don't know what you should have been shown...or the opportunity never presented itself before. Good luck,
Mark
Thanks for the suggestion, Tom --- you definitely make it sound easier than I thought it would be.
Thanks, Danny, for the part number; that'll make it easier to find what I need, I think. At the risk of sounding TOO dumb, is 'A39' a Yanmar number or is that a universal belt number?
For the record: I'm not stupid about everything. Computers, I know. Tractors, I don't. ;)
Eddie, you have a PM coming.
   / Getting a Yanmar repaired #7
You're welcome. Sometimes working the belt into position can be a little frustrating. The clearance between the fan and the radiator on my tractor is tight enough to make getting the belt around the fan a little more trouble than it should be, but, all in all, it's really not a difficult task.
It's a universal V-Belt size designation. The "A" identifies the belt's cross sectional size and the "39" is the belt's length.
You proved that by asking the question.:)
   / Getting a Yanmar repaired #8
I wish I knew computers:(
   / Getting a Yanmar repaired #9
I sure hope it's not stupid if I don't know about something:eek: :eek:
I have been in a fight with my computer last couple of days, changing out hard drive without loosing data on old one. also adding DVD burner.
I think it's easier to learn about tractors than it is computers:rolleyes: :rolleyes:
Fred, you have PM coming back to ya.
   / Getting a Yanmar repaired #10
Fredster,
I am from East Limestone and recently back from Iraq. If you get the belt and let me know a time, I can swing by there sometime. I have been busy catching up here this last week. I need to get my hands dirty on a tractor again.
grapple for mini skid steer (A53421)
grapple for mini...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2016 Nissan Frontier Ext. Cab Pickup Truck (A53422)
2016 Nissan...
2019 Ford Fusion Sedan (A51694)
2019 Ford Fusion...
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
