Getting a rim off of a '67 Massey 135...
   / Getting a rim off of a '67 Massey 135... #1
BobG_in_VA
Veteran Member
Central VA, USA
Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
Finally have to change out the original Goodyear rear on my '67 135...I already did the other one a couple of years ago...so its not like I haven't done this before,,,,but....I've got it jacked/blocked up, all the rim bolts out (6), but that darn rim wants to stay with the center (as this is the orginal that's been on there for 46 years, I'm sure the center and the rim are good friends that have "bonded" --grin)...any fresh ideas on how to pop that rim off the center (while center is still on the tractor)? PS: its just me here, so I need a one guy solution.... BobG in VA
   / Getting a rim off of a '67 Massey 135... #2
Plenty of spray penetrating oil and a big hammer from the back side of the rim. Rotate and hit again. Once you get it off file the center hole of the rim with a half round file and apply never seize to axle and rim before putting back on.
If that still doesn't get it loose, put the bolts back on but leave them a turn or two loose then drive tractor a few feet or around in a circle then jack up and try again to remove.
   / Getting a rim off of a '67 Massey 135... #3
I agree with this post but as you spray penetrate on tap around with ballpeen hamer as this sometimes allows oil to get in between rim and hub. I us emrory cloth to polish hub and rim
Thanks guys..I'll these ideas a try tomorrow..(new tire and tube are due in on Tues.)..Mo' later. thanks again. Bobg in VA
2015 DODGE RAM...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2015 FONTAINE TRAILER CO. 53 STEP DECK SPREAD AXLE (A50854)
2015 FONTAINE...
2007 PETERBILT  385 CAB AND CHASSIS (A50854)
2007 PETERBILT...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
2016 VOLVO VN SERIES SLEEPER (A50854)
2016 VOLVO VN...
