Getting a higher cutting height w/ JD 265?
   / Getting a higher cutting height w/ JD 265? #1
Verticaltrx
Veteran Member
VA
Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
I have a 265 Deere garden tractor with the 46" deck. It has always cut shorter than I would like and with the dry weather we've been having it would be nice to cut a little higher. It seems like with the deck all the way up (in the transport lock even) it only cuts about 3" high. We used to have a 180 Deere (same 46" deck, smaller tractor w/ different lift system) and it would easily cut 4-4.5". What am I missing here? Or is that just the way it is? Thanks in advance.
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
2016 MACK GU713 GRANITE DUMP TRUCK (A51222)
2016 MACK GU713...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
Zero Turn Mower (A48082)
Zero Turn Mower...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
