Keep in mind guys what I am trying is the non-metallic version. There also is a semi-metallic. The are what we'd classify as "rolled" materials, which is what keeps them flexible. The OE material was a heat and pressure cured lining, very stiff. At least for my tractor, the production lining that came on the vehicle was asbestos, so it was a non-metallic, why I chose it.
For my tractor about 3ft of the lining was enough for both sides. So along with the epoxie, 3 hose clamps and shipping, I think I spent about $25.
Make sure you let the epoxie cure for the time it states on the packaging. I used the slower cure 4-6 hrs with an overnight cure. The 5 min or short cure materials may not give you enough time to set the compression clamps. Long cure epoxies are also better at cross-linking, giving you more strength. And a warning. If you never have worked with epoxie before, one of the cure accelerators is bisphenol A. Some people are allergic to BA and develop a skin rash like poison ivy.
And tractors built before the mid to late 80's used asbestos linings from Japan.
