kthompson
Elite Member
- Joined
- Sep 12, 2008
- Messages
- 3,509
- Location
- South Carolina
- Tractor
- Kubotas B2710, M6800, L6060 cab, Volvo EC excavator, 2 ZTRs and various implements.
I am planning on a water circulation system to cool and heat our dog house. Talked with a good friend who owns an hvac business who works some with geo therm and he gave me some recommendations. But have some points hope you can help me with. Built the dog house ourselves. about a four feet square and three feet tall. Walls have two inch foam in them and the "attic" is insulated. Seems odd to say attic in dog house but still an attic. Nope, no stairs.
Was told about 5 feet deep will give me stable temp about 50 or do degrees F. If the house is heated to even 45 degrees F that should be plenty but our summer temps can reach 100 for days with high humidity. I think copper would be best material for the temp transfer in the ground and in the house. My first question is what would be the second best option in material? Believe pex would be lowest cost option. Next is the diameter of the pipe or tubing needed. I think 1/2 inch would be fine. Yet when I read the gpm it seems too small. Any idea the gpm needed to produce the temps desired in the house? Plan to make a copper coil or such design to lay on the floor with suitable material over it (need thoughts on this also) to serve as a radiator. Am planning on using a water pump for small pond as what I understand being a loop the pump is not really lifting the water like in a well.
Any other recommendation..
Thanks.
Thanks.
