genny question on 66' IH CUB
   / genny question on 66' IH CUB #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
genny question on 66\' IH CUB
Howdy
I've got a 1966 IH cub ( 12v ) and a cow got in the barn last night and ran her horns all over it. Pulled ignition and plug wires, and pulled the wires from the genny as well.
Ignition and plug wires were easy to figure out.
Genny is a bit harder. Can anyone tell me which terminal is the field, and which is the armature? Give location, as the genny is still installed and hood is on. As all you cub owners know, the genny is all but inaccessable with the hood on.. and I really don't want to pull it ( and gas tank.. and dash.. etc ) unless I have to. I can get my hands in there to re-attatch wires.. but that's about it.. can't see what I'm working on.
If someone can identify the arm / field I'll be good to go.
Off hand.. anyone know if this is an A-circuit or B-circuit generator? Since it was disconnected for (??how long?? ) I want to repolerize it.. but will need to know circuit type to do that.
thanks
Soundguy
   / genny question on 66' IH CUB #2
Re: genny question on 66\' IH CUB
I know I'm not answering your question but we totally rewired dads farmall b last year,if I had his book here they would probably be close enough that it might show something to help,but something I have found out working on the 6 volt farmalls is that,there are certain times that you need to polarize the voltage regulator,and something else we found to be out of adjustment on about all of his tractors was the govenor,and then theres a certain way you hook the wires up on the regulator it is supposed to charge more. I don't know if this info. will help you out that much but if you think that it will then I can get his book and give you specifics,I'm sure they have to be very close on the settings,let me know.
   / genny question on 66' IH CUB #3
Polarizing the regulator is only necessary when you replace it with a new one. Once polarized to the existing genny. it never needs to be done again.
My failing memory recalled this from the days when everything that I worked on had a genny/reg. system, before alternators. ****. Never thought I'd get this old.
Richard.
After working on these old fords.. I find that any time the battery is out for long periods, the genny is idsassembled, or the regulator is swapped.. a polarization is necescary. The genny on my ford 660 lost it's polerization just during a battery swap.. however I've had the battery out of my 8n for months at a time and never had a problem.. go figure.
Here's an update on what I found..
Ok guys.. I got a funny one for you guys.
Here is some background info.
Some time ago ( last year at the end of mowing season) one of my cows got in the barn and ran her horns all over my 1966 IH cub. Pulled the ignition and genny/regulator wires. I put the ignition back together, and frankly.. just left the genny disconnected, as I could mow all day, and never know the difference. i use solar 'maintainers' on the tractors.. and over the course of a week, the battery was topped back off.. So I never had to jump the unit.. so that kept me 'lazy' enough not to tear into it. Besides all the other farm stuff that needed to come first. I decided to get into it yesterday and today.
Ok.. unit is a 1966 IH cub. According to SN it is one of the first units that was 12v. The I&T manual is a little stingy with exact regulator and genny info.. though there were -MANY- 6v generators used, and a couple 12v gennies. same with regulators too.
At this point.. I'm going to guess that this genny has either been rebuilt, or is just plain not oem. It's armature and field terminals are reversed from what the schematics show on all the other gennies. It is a delco unit, and does fit the oem mounts Here's where it gets funny. The 12v units, in the book, are negative ground. After fiddling with it, and doing a bunch of testing, nd work.. this unit simply will no longer charge as negative ground. I even pulled the regulator completely off, and full fielded the genny and measured the armature, after polarizing it first. No charge.. nothing.
i swapped the battery to positive ground.. polarized the genny.. and it charges perfect. I'm using a big diode and a 3 ohm 10w power resistor as my 'regulator' right now. I'm going to test the genny tomorrow to see if it will run positive ground. The genny is obviously a 'replacement'.. new vintage.. does say 12v on the bottom of it. Deffinately is an A-circuit genny, due to the placement of the external resistor from the field tab, wired to the mounting plate.. providing some field resistance even when the contacts are open.
The genny responds as an A circuit as well.. ( oem was a- circuit too.. Hmm )
In all other respects, this genny checks out. Brushes look good.. good commie.. no shorts I could find.. etc. field insulation intact.. correct field amperage range of draw according to the fo manual, and even correct voltage and current output range on the armature. ( up to 14v and 25a.. and yep.. it will pump that out.. 14v max.. and 20+ amps when full fielded. )
Unit motors and does have a current draw at the armature, with the armature and battery jumpered ( as it should).
I looked like a mad scientist out there today. I had about 50 jumper wires and 3 VOM's set up and going. measuring field draw, armature output and battery voltage, the tractors ammeter was also in circuit showing 'net' charge.. etc. All looked 'good' and what I expected. Output was a nice 'dirty' dc 'waveform' according to my o-scope.. exactly as I expected it to be.. and have observed from my other gennies..
I have noticed a few other peculiar things about this tractor. It was sold as a 51 cub.. but clearly is a 65+ due to the sheet metal, and other features, like seat frame mounts, hydro pump, etc. The wire diagram for all the new units is straight 'regulator' run for the genny charge, while some older units did also use a lamp switch resistor wired to the genny, and no connection to the field tab.. according to some of the 6v diagrams I could find... This tractor does have a lamp switch equiped with that resistor.. however it was not wired to the field. I wonder if the lamp switch was a 'one size fits all' model, and was just universally used?
In any case. I'm going to dink with it omorrow. but really need to button it up, as I can't spare much more time on it. I'll test the vr to see if the cutout is still working and if the voltage contacts work.. if so, I'll install it and polerize it as positive ground and just run it that way,as the genny is fine with that... I fhte regulator is cooked.. I think I'll leave my diode/power resistor setup, possibly with a toggle switch option to switch in some more resistance so i can have a low/high charge setting.. perhaps even use the built in resistor in the lamp switch??
I'm still puzzled why it will not run negative ground. the armature and field being in different locations from the book lead me to believe this is not the stock genny.. but one the owner found that would fit the brackets...
You guys know of anything that would lock a genny into one polarity?
Comments and ideas welcome.
soundguy
Dilema solved.
I messed around with it all morning.. got the regulator working good, and finally got the genny to polarize as negative ground. Just out of the blue it started working.
After further investigation... I think I had some dirtyterminals, and a partial short of the field post giving me some problems.
Works great now. Genny will run ignition, and 3 55w lamps, and still kick about 2 amps positive for charge, at mid throttle and up.
Soundguy
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2024 John Deere 6120E MFWD Tractor (A53342)
2024 John Deere...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
100 GAL FUEL TANK W/ PUMP TOOLBOX COMBO (A52472)
100 GAL FUEL TANK...
2017 Chevrolet Express Box Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
