Generic or locally available Glow Plugs for 1526
   / Generic or locally available Glow Plugs for 1526 #1
jaredyates
Hickory NC
Mahindra 1526, Kubota M7040
My searching hasn't turned up a cross reference for the glow plugs on a 1526. Has anyone figured it out? The OEM part number is 32A6603102 and Sherwood lists these other tractors as being the same:
SERIES MODEL
16 Series 3016 Gear
16 Series 3016 HST
Max Series Max 22 HST
Max Series Max 25 HST
Max Series Max 28 XL HST
Max Series Max 28 XL Gear
Max (T4 Series) Max 24 HST
Max (T4 Series) Max 26 XL Gear
Max (T4 Series) Max 26 XL HST
1500 Series 1526 Gear 4WD T4
1500 Series 1526 HST 4WD T4
1600 Series 1626 HST
1600 Series 1626 Gear
Max XL Series Max 26XLT HST
Max XL Series Max 26XLT Gear
Max XL Series Max 25 XL HST
When I search on ebay I get one expensive match for the 1526 but when I search for the engine (S3L2) I get lots of options that are more reasonable, but still not as cheap as the local auto parts places.
   / Generic or locally available Glow Plugs for 1526 #2
If you go to the NGK website they can tell you the NGK model for that tractor. It was from them I learned my (used) tractor had the wrong glow plugs installed when I bought it.
   / Generic or locally available Glow Plugs for 1526 #4
You might do the search under the Mitsubishi engine model number (S3L2) and not Mahindra. The Mitsubishi engine was far more widely used than just Mahindra. I have the same engine in my LS.
   / Generic or locally available Glow Plugs for 1526 #5
Instead of going down a list looking for your model tractor try the "Contact Us" option. I think that's the route I followed. Specify as much information as possible about your tractor (brand, model, engine type, cylinders, etc). They do respond with information.
Good tip, thanks! I have sent a message and will report back when they reply.
NGK replied to say there are no aftermarket options, but for some reason I suspect that they are just using the same form that I'm using.
6' DISC HARROW (A51243)
6' DISC HARROW...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
2015 Ford F-150 4x4 Crew Cab Pickup (A50323)
2015 Ford F-150...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
Lightweight 5' Pipe Gate (A50515)
Lightweight 5'...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
