Generator to Alternator conversion
/ Generator to Alternator conversion #1
Bobby R
1972 Ford 2000
I'm wanting to convert the generator on my Ford 2000 to an alternator. I'm wondering if there's any special wiring that has to be done in order to accomplish this? Also is there a certain alternator that I have to purchase in order to make it mount without a lot of modifications? And finally, what do I do about the tachometer and hour meter that currently connects to my generator? Any input, suggestions, or ideas will be appreciated.
/ Generator to Alternator conversion #2
I've done a few of these conversions (none to a ford) using old delco 10si alternators. You should be able to find a tach drive for that alternator as well, I had my local shop order me one for a used 10si from the wrecker...
/ Generator to Alternator conversion #3
Most Delco "one wire" alternators are available with a "Tach" terminal, I don't know how your hour meter is wired to the alternator, but I understand WHY. Unless the generator is charging (engine running) it will not count hours even with the key on. Most alternators have an available B+ output for this as well, or it can be added.
Be careful not to go too large, that is, tractors have VERY limited electrical needs, an alternator that will charge 20A or so is probabally more than enough.
As for connecting the alternator and making it work, nothing could be more simple. You connect the B+ cable to the B+ terminal on the alternator, make sure the case grounds to clean metal on the upper and lower mounting bosses and that is it!
/ Generator to Alternator conversion #4
Most Delco "one wire" alternators are available with a "Tach" terminal, I don't know how your hour meter is wired to the alternator, but I understand WHY. !
I think the ford has a mechanical tach, not electrical.There is a speedometer type cable running it.
I would NOT use a 1 wire alt, pretty simple to hook in a diode. I would suggest that you travel over to ytmag.com and search the ford forum for alternator conversions. More old iron guys there.
Thanks for the information, guys!
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
2013 Ford F-350 Knapheide Service Truck (A61573)
2013 Ford F-350...
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
2016 International WorkStar 7400 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2016 International...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59912)
2021 KENWORTH T680...
