Generator oil leak
   / Generator oil leak #1
shui5612
Montreal
2013 Yanmar SC2450, 2008 Kubota ZD326, 1986 Deutz 7085
I have a standby diesel generator that leaks oil since day 1.
The issue is, I have looked EVERYWHERE for the leak and cannot find it.
Here's where it gets even more confusing : the engine oil is dark (like normal used oil), while what I find on the floor is a lot lighter. I.e. like new synthetic. The engine oil level does not decrease either.
There isn't a diesel leak anywhere either.
Do you guys have any tips on locating a leak? Is there some sort of dye that could be added to the oil ? Kind of like the ones used for a radiator or ac system..
The generator is a sealed /quiet type therefore access is limited unfortunately.
   / Generator oil leak #2
What make and model is the generator? What engine? What country was it manufactured in? Do you have a link to an online exploded parts manual? A shop manual? My first thought would be a leaking gearbox seal, but without more info I couldn't even say that it has a gearbox. If the engine is low RPM, it probably has one. What does your owner's manual say?
The owners manual is of no help, it's a generic diesel Chinese generator called a gt power gt6000w.
Leak is somewhere near the bottom of the generator.
Is this dye visible in dark engine oil with a good UV flashlight?
Do I have to do an oil flush/change after or can the dye stay inside the oil for say a week or two if the leak isn't apparent at first?
Thank you for the help.
5 Shank Inline Ripper (A50514)
5 Shank Inline...
2008 MAGNUM LIGHT PLANT (A50854)
2008 MAGNUM LIGHT...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2006 Volvo VNL (A51039)
2006 Volvo VNL...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
