FredH
Platinum Member
The 4000 watt generator head went out on my APU on my Semi , front bearing . Going to see if rebuild-able by a couple of places in town . New O.E.M. replacement is around $1500+ !!! Old style head it appears . Has a large Capacitor mounted to a bracket on the back end but in the final wiring , you still have just 3 wires going to unit inside cab .
So My question for you Guru's is this , Why not replace with a Brushless head from Northern Tool like this one :
NorthStar Belt Driven Generator Head — 5500 Watt | Generator Heads| Northern Tool + Equipment
Add a new pulley / sheave and also a belt tensioner , ( old garbage had a flippin' Bolt through a plate with double nuts on both sides to adjust ) plus make my own mount off the current mounting points on bottom of motor and frame . No Way for it to fall out even if mount failed , ( Not Likely ) or bolts failed as entire system is inside a box .
I would Basically still have the same power , But not understanding the difference between " Brushless " and the old one that I assumed had brushes and this flippin large capacitor on one end ???
Any Ideas ??
Thanks ,
Fred H.
Any Ideas ??
Thanks ,
Fred H.
