generator diesel
   / generator diesel #1
texastomtom
Texas
JD 4720 2004 / MF230
Anyone have any comment on the sd060 60kw generator from generac...... series 2000
I found one on ebay for 8500,,, 2002 model, new with 0 hours ?
Sounds like a deal and is in texas...
I have been lookin for my business.... This is larger than I need but for this price.... Actually uses less fuel than the smaller version of it as well... Deere engine
Comes with 200 gallon tank mounted with it....
enclosed unit,,, does not seem to come with the xfer switch but that is no biggy....
Thanks for your time !
tom
   / generator diesel #2
There have been some bad experiences with light duty gasoline Generac generators posted here on TBN recently--bad service follow through by Generac. But, what little I've seen (specs) seems to indicate that the big Generac units are not a cheap commodity product and should be a little more durable. Buyer beware!
But, at that price, I think I would check out the unit. By that, I mean go look at it and buy it on the spot if it looks good. Take a few electric heaters with you for a little load, 2 or 3 KW is better than nothing. Be prepared to have to wire a plug in though. The big units rarely have convenience outlets on them.
   / generator diesel #3
Tom I've had bad experiences with Generac. Do yourself a favor and go online and try and find their warranty and read it. For mine comercial custumers only get a 6mo. waranty on the engine and 1yr on the generator part.
And lets say you need it for a project thats OFF THE GRID (meaning no power going to the home or using it for emergency power to power your home) It's not covered under waranty. Got that right from the Tech himself. /forums/images/graemlins/mad.gif
   / generator diesel #4
Um.. if it's not to be used when there is no power..? when do you use it? /forums/images/graemlins/grin.gif /forums/images/graemlins/confused.gif
That's kinda like a life raft that says not to use in wet conditions? /forums/images/graemlins/shocked.gif
Soundguy
   / generator diesel #5
Also make sure there are no regulations against using it at a business. Even in Texas, generators are regulated as to their use and when they can be run for a business. That was a point made sometime during Enrons fiascal and its power sales to California.
   / generator diesel #6
</font><font color="blue" class="small">( <font color="blue"> if it's not to be used when there is no power..? when do you use it? </font> )</font>
Strange, isn't it???? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
They may start a new advertising campaign stressing the fact that they will give a 25 year limited warranty, while in the small print there is a disclaimer that it's valid only as long as you don't start it up.
   / generator diesel
I've read some of the bad stuff about generacs here.
Seemed like mostly it was the smaller stuff...
This is a fairly big diesel with a deere engine...
I am still weary of generac though ....
I wonder how many people would have a 60kw at their house ? So I would think the warranty would mainly be for commercial.... I will however look and see..
Based on you guys comments here,,, I'll probably just pass...
New Holland 325 Manure Spreader (A55218)
New Holland 325...
12ft Heavy Duty Aluminum Ramps (A55301)
12ft Heavy Duty...
2019 Kubota SVL 95-2 (A47477)
2019 Kubota SVL...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
