Generator build
   / Generator build #1
schmism
Super Member
Peoria IL
New holland TC(33)
I seem to have a collection of vertical shaft single cylinder engines commonly found on riding lawnmowers. 12-16hp range.
Some of these are still in frames of old lawnmowers others are sitting on a shelf.
Id like to do something productive with them, and the idea of converting one or more into generators sounds appealing.
Most standard generators are direct drive.
anyone converted a vertical shaft to horizontal shaft operation? is there anything fundamentally different between the 2?
is there a source for 3600 rpm gen heads for direct drive on 12-16hp engines?
anyone bolted a genhead to the front of an existing riding lawnmower.... belt driven off the exisiting drive pully?
   / Generator build #2
Gen heads generaly don't have crank cases - you might have better luck keeping the engine vertical, and mounting the genny next to it... Steve
2006 Isuzu NPR-HD Landscape Dump Truck (A53422)
2006 Isuzu NPR-HD...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
(4) GOODYEAR WRANGLER 275/55R20 TIRES (A54757)
(4) GOODYEAR...
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
