Generator brands
   / Generator brands #1
handirifle
Veteran Member
Central Coast of CA
Massey Ferguson 1010
OK this is more RV related, but it will be used at home in emergencies. I want to get a 3-4KW generator for my RV, and I know the top models are the Yamaha and Honda units, but honestly at $2300+ they are pretty much out of my range. I see some units that have been considered reliable for about 1/4 as much. So with that, are the Yamaha's and Honda's 1/4 as quiet and 4 times as reliable?
I also know air cooled motors are more efficient if there is little or no back pressure on the exhaust, but surely one could be muffled enough with no increase in back pressure, right?
Are there some more affordable brands that are quiet and reliable?
   / Generator brands #2
Sadly for camp ground use, I haven't seen anything better than the Honda and Yamaha...I'm in the same boat. I have a 9,000 watt generator that is very quiet as far as they go, we took it to camp to power 2 other campers while I ran my on-board 4k in 100+ degree heat...The aluminum echo from the campers was unreal, and we have very generous spacing...If you are going to use it a lot, spend the money, you won't regret it and neither will your neighbors.
Now that I have a TT, I have to do some shopping if I can't get the power company to bring me dedicated power (a whole other story).
If there's something I'm unaware of, I'm open to suggestions...one other thing, on my camper I have to power 15k for the AC surge...That requires a boost on the portables that equates to a 3500 or so surge.
   / Generator brands #3
For the money the TSC units made by Champion are excellent. Little loud but $300. My father has a 4000 watt unit with a 30 amp RV plug on it. I know 2 others with it that are pleased. With AC on its just a steady hum.
Chris
   / Generator brands #4
What's a 'TT'?
   / Generator brands #5
I second DPs opinion on the Champion. We've had one for about 4 years or so now. We've lost power a few times and it has always worked well. In 2012 we had the derecho come through and we lost power for 4 or 5 days, it ran constant except for shutting down for fueling and checking (not changing) the oil. We moved to the camper for those 4 or 5 days where we could have AC. I then borrowed a generator (and finally on Sunday bought a Generac 5500GP at TSC they had a bunch brought in) to power the refrigerators and sump pump and stuff in the house. The Generac is much louder and doesn't put out as clean of power as the little Champion. The Champion also starts much easier, usually on the 1st or 2nd pull. Back to the Champion and the power outage, we were able to run everything in the camper except for the water heater on electric. If it kicked on and the AC was on, it would stall the generator. Other than that it did fine including running long extension cords and running fans for our goats. Our camper sits beside my 30x48 pole barn, I set the generator in front of the pole barn on the concrete approach with a chain wrapped around the frame. Ran the chain under the door and then parked the truck on both ends of the chain (did the same thing for the generator at the house), once we were in the camper with the AC on, you couldn't even here the little Champion running - though I could hear the Generac much farther away. Now, I'm not saying I would run the Champion in a campground as part of normal camping, but for emergency use, I think $300 is a very good investment. When we bought ours they were $299 and I got a $50 gift card. I believe now they are $329 and you might see them on sale for $299.
   / Generator brands #8
I am very happy with my Honda Eu2000's bought them 10 years ago and they are still running great. I made my own cable to run them both when I need to run the AC but 99 percent of the time its only one.
I used one all week last week as a power source for power tools while building a boat dock. Had someone come over to see what I was doing and after I turned the radio off he asked is that generator running. lol I highly recommend the honda eu units they make camping a fun experience not a noisy bothersome event.
   / Generator brands #9
I have a Yamaha ef2400is or 2400 watt. It will run our travel trailer AC but that is about it, forget about a coffee maker or microwave at the same time. We usually only run the AC for a short time in the evening to cool the camper down. It has been reliable and it is quiet.
   / Generator brands #10
As has been stated above, Honda and Yamaha are the quietest, Champion seems to be the best of the Chinese brands. That said, don't under estimate how much generators annoy fellow campers. If you don't need air conditioning, just about anything else can be handled with propane and solar panels. The price on solar panels has dropped dramatically in the last year or two.
2018 HINO 258 SERVICE TRUCK (A51243)
2018 HINO 258...
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
2020 FREIGHTLINER 26FT BOX TRUCK (A51219)
2020 FREIGHTLINER...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
